22-08-2010, 05:03 PM
BSOD..Prob with 1600mhz ram ??
I received my system on friday, installed fresh OS (Win7 64 bit) after formatting whole HDD.
Now, I am getting BSOD.
Found errors on ram (using Memtest)
Edit: Just found on corsair website
That the Ram I have CMX4GX3M2A1600C9
-Supports Intel Extreme Memory Profiles.What does this mean ?( ( http://www.corsair.com/products/xms3/default.aspx)
- Not listed in DDR3 Memory for AMD Phenom II Processors ( http://www.corsair.com/products/phenomii/default.aspx)
Is there any setting req to be done in BIOS as it showing ram at 1333mhz instead of 1600mhz.
Mobo : MSI 890gxm g65
Ram : Corsair CMX4GX3M2A1600C9
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
22-08-2010, 05:39 PM
geek........
Re: BSOD..Prob with 1600mhz ram ??
RMA your ram ASAP
22-08-2010, 08:24 PM
Super Moderator
No need to RMA it.
EPP = Extended performance profile. Out of the box your RAM will operate at 1333 you would need to make BIOS changes to get it to operate at 1600MHz. The changes would be the DRAM voltage and the FSB : RAM voltage.
What errors you got using memtest.
23-08-2010, 09:15 AM
I checked the rams (individually on Slot 1) using Memtest 4.10.
Found errors on one Ram, other found No errors.
23-08-2010, 11:03 AM
Super Moderator
RMA it then.
23-08-2010, 11:08 AM
--> Is there any bios setting required or it's confirmed that Ram is faulty ?
--> I have seen in Corsair forum that BSOD problem may occur due to Cpu bent pin...I think..if that's the case...both ram will show errors...rite ?
23-08-2010, 11:16 AM
run it with just one stick which has no errors, check for stability. Btw, RAM is running at 1333MHz and not 1600MHz, you need to manually set it to 1600MHz.
23-08-2010, 11:18 AM
^^I am running my system with one stick.....No errors
23-08-2010, 11:58 AM
is there any xmp profile setting in bios ?
23-08-2010, 01:18 PM
Super Moderator
It will not be a switch setting. He would need to change the FSB : DRAM ratios.
23-08-2010, 01:52 PM
CG Artist++
@aniket bajaj .please let us know the bsod massage, if possible contact smc hardware technican , tell them you are getting that bsod massage , they will suggest you wat to do, nd no need to rma ,if ram is faulty just go to smc they will change your ram? Same thing happened with me i purchased g-skills ripjaws and it shows of IRQ IS LESS THAN EQUAL BSOD i contact them ,they informed me to bring my cabby or motherboard , proccy nd ram  i took my ram next day ram . And make it replace from their shop ,  i will so you their no.
23-08-2010, 02:11 PM
^^ Same BSOD : IRQ IS LESS THAN EQUAL
They replaced your RAM, same day ??
23-08-2010, 04:35 PM
CG Artist++
yes they replaced my ram same day
24-08-2010, 01:52 PM
^^Talked to Sachin....Will replace ram same day.
What Bios settings u have done to get ram at 1600mhz ?
25-08-2010, 07:23 AM
My friend is having similar probs. both the ram are free of errors when checked single . Both the ram slots are working fine. The problem occurs when he install both ram in dual channel mode.BSOD occurs or Sys got restart. win 7 setup also was not installing.
After some research it was found that CORSAIR HAVE DIFFERENT RAM FOR AMD AND INTEL which run on different volts . that's why having prob. my friend has purchased ram for core i3 processors. only corsair is selling this type.. all other companies like gskill, kingston ram can be used with amd or intel.
my friend temporary sol.
1). install os with only one ram.
2). now put 2nd ram in same channel and not try to make it dual channel.
Some technician at nehru palace has said that intel ram runs on low voltage and amd at more. So, incresing voltage will solve problem. Is it true????
Secondly , he has purchased from cost to cost ,nehru palace with amd 955 b.e., msi mobo.. can they replace it on this grounds. Ram is open na. he has also throw away the box. or corsair company will change stick and cud give the amd ones.
25-08-2010, 09:58 AM
Super Moderator
Bajaj, Akhil:
Please tell me your exact RAM model numbers.
25-08-2010, 11:21 AM
^^Model : Corsair CMX4GX3M2A1600C9
SMC replied "Aisa kuch nahi hai...Sab chalti h"
---------- Post added at 11:21 AM ---------- Previous post was at 11:18 AM ----------
1) I checked both the rams on same slot using Memtest 4.10
Errors found on 1 stick.
2) CORSAIR HAVE DIFFERENT RAM FOR AMD AND INTEL
Please provide the link or source...
25-08-2010, 01:25 PM
I asked SMC to replace it with Gskill.Tell me, which one is compatible with MSI 890gxm & Phenom X6 1055t
Gskill Ripjaws 1600 Mhz 4 GB(CL7) DDR3 Kit
Gskill Ripjaws 1600 Mhz 4 GB DDR3 Kit
25-08-2010, 01:33 PM
#19 (permalink)
yes, Corsair sells some low voltage rams for Intel i series. not sure whats the benefit other than saving a couple of Watts.
@Akhil, let me guess, your friend using an Asus motherboard? these errors most common in Asus boards. specially for AMD system. if you run 2 ram in single ch mode (ram in alternate slots) the ram will work, in dual ch (corresponding slots), BUMP !!! ERROR. the ram maybe faulty too but mostly its the board thats faulty.
26-08-2010, 07:17 AM
#20 (permalink)
Not listed in DDR3 Memory for AMD Phenom II Processors ( Welcome to Corsair :: Phenom II Memory)
The mobo my friend is using msi ( unlock cores and can overclock) based on 890 chipset.
High end model costing him rs. 7k...( "supports max 1333 mhz. but also supports 1666 mhz with overclocking" was written in manual).
the ram was some gamer edition (1666 mhz kit containing two sticks with 2 GB each with heat sink). however it was written on the box that they also support triple channel. indeed Packaging was such that main cardbox contain three plastic boxes inside . in which 2 have sticks while third was empty. it was written on box the quantity 2*2 gb = 4gb. so itwas seal packed . (costing rs.6k while gskill was only 4.2k)
checked with memory daignostic test provided in ms indos 7 DVD.
no problem detected. we have checked sticks one by one in diff ram slots. the error comes only activating dual channel. if i put both ram in black slots then they run smoothly or blue slots then also... so slots on mobo are also right.
my friend have thrown away boxes , so in evening i will go his home and see whether model no. is written on ram modules or not.
check Welcome to Corsair they have diff. sections for memory. intel memory solution and amd memory solution
you are lucky that smc is replacing ur sticks. go on and replace it.
---------- Post added at 01:47 AM ---------- Previous post was at 01:43 AM ----------
the mobo is msi based on 890 gxm with amd 955 be processor.
yes the ram works fine in single channel mode but mobo is not faulty bcoz i checked.
one gskill and one kingston ddr3 ram work perfect in dual channel. so no probs in dual channel.
26-08-2010, 09:35 PM
#21 (permalink)
okay return from friend's house. here his config
Amd 955 B.e.
Msi 880 e-45
ram cmx4gx3m2a160c9 running at 1.65 v
while for amd it shud be
cmx4gx3m2b160c9 running at 1.8 v
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/131083-bsod-prob-1600mhz-ram.html
| Posted By |
For |
Type |
Date |
| Advice on 23k Gaming PC |
This thread |
Pingback |
05-09-2010 05:21 PM |
