Old 20-08-2010, 11:34 PM   #1 (permalink)
Default Hardware problem with Intel Chipset
Hi
After I reloaded XP when I check up the Device manager at one place yellow question mark is shown. I checked the properties
and the following is displayed as the location.
" on Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8 "
please tell which is the driver for this?
M/Board : Asus P5KPL-VM
OS: Win XP Prof. with SP3.
I uploaded the screenshot, the link is :
http://www.4shared.com/photo/yfnVvqpa/screen1.html
gramesh is offline   Reply With Quote
Old 21-08-2010, 10:41 AM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: Hardware problem with Intel Chipset
Hope this helps
ICH7 chipset
Try to update the USB Drivers.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 21-08-2010, 11:26 AM   #3 (permalink)
Hi rajkumar_pb
thanks for your reply, but in the Device manager USB controller is not showing any yellow mark?
Old 24-08-2010, 08:04 PM   #4 (permalink)
From the screenshot it looks like you have windows 7
If its so fetch the following link:-
ASUSTeK Computer Inc. - Motherboards - P5KPL-VM
Best of Luck !!!
sanju_nlp81 is offline   Reply With Quote
Old 31-08-2010, 12:27 AM   #5 (permalink)
Best of Luck !!!
Yes I installed win 7 in addition to xp sp3 and took the screenshot from win7.
I d/l the file from above link when I tried to install it says you already have higher version of the file?
Old 31-08-2010, 10:25 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Reinstall all the chipset drivers for the motherboard. Just over lay them.
asingh is offline   Reply With Quote
Old 31-08-2010, 10:29 AM   #7 (permalink)
pegasus's Avatar
Installing chipset drivers should have worked i feel.
Do you have the original CD/DVD that came wit the motherboard?
pegasus is offline   Reply With Quote
Old 31-08-2010, 03:23 PM   #8 (permalink)
Sorry I lost it somewhere.
---------- Post added at 09:53 AM ---------- Previous post was at 09:52 AM ----------
you mean to say overwrite drivers?
This Guy Definitely Has More CPUs Than You Do topgear Technology News 20 18-08-2010 06:08 AM
Computer Problem (Sound skipping) Adam Cruge Software Q&A 2 04-06-2010 06:56 AM
Intel core i5 processor + Intel MotherBoard DH55TC supported Operating Systems dkverma87 Hardware Q&A 3 17-03-2010 02:09 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Intel 965wh Audio : Sigmatel - Problem s18000rpm Hardware Q&A 2 31-12-2007 03:27 PM
