Old 19-08-2010, 10:26 AM   #1 (permalink)
lahratla's Avatar
Default APC UPS cannot hibernate
I have APC Back-UPS ES 650Y-IN. My PC is dual-booted with Windows XP SP3 32-bit and Windows 7 64-bit. The APC PowerChute Personal Edition 2.2 works fine in Windows 7. It can gracefully hibernate/shutdown the PC as per the runtime settings in the software. But the APC PowerChute Personal Edition 2.0 in Windows XP is unable to gracefully hibernate/shutdown the PC as per the runtime settings in the software. I have disabled several services in Windows XP. Could this be the reason? On which services the software has dependency? Or could it be due to some bad drivers?
Besides, can the PC resumes from hibernation when AC power comes back? If so, what settings are required?
lahratla is offline   Reply With Quote
Old 22-08-2010, 12:11 AM   #2 (permalink)
Point Blanc
Default Re: APC UPS cannot hibernate
call up APC people, they certainly would help you out. I have taken on APC because there support is good.
acewin is offline   Reply With Quote
Old 22-08-2010, 09:34 PM   #3 (permalink)
lahratla's Avatar
they have not been able to resolve the problem and that is why I am asking for help in the forum
UPS (Uninterruptible_power_supply) and UPS battery Buying Advice? Help Digitians!!! RajivKumar123456 Hardware Q&A 6 02-07-2010 11:41 PM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
APC UPS VS Microtek Double Battery sincereheart Software Q&A 14 31-07-2005 01:25 PM
APC UPS Model Number undecided - Final decision awaited...!! sincereheart QnA (read only) 3 25-07-2005 01:34 AM
