Hi asigh..
It goods to hear from you,
I am a bit against to OC, honestly i dont find any logic behind OC . When you are really playing a decent game smoothly then what's the logic in stressing your CPU with OC?
Few months back i used the default gigabyte tool set up to OC the cpu.....to 3.4ghz....I used for a couple of days but really didnt not noticed any greater efficiency boost.
Instead I somewhat felt a bit uneasy....sytem staered crashing in between movies .... and downloads ( I often download for 4-5 days continuously)
So i stepped down from OC to normal load...and the problem was solved....So i really dont care to OC any more...
However for the past 1-1.5 month problems started.....NB really really hot...unable to touch it with bare hand after sudden shutdown...at room tem 32`-40` C.
I was really happy with the board but something is not right.....Something is really not right with the board....Did i again screw up the system with the OC 6 months back...or it is the normal wear and tear of the board?
As per your post :
pt1 : Irrelevant frm my point.
pt2 : Irrelevant frm my point.
pt3 : Irrelevant frm my point.
pt4 : Accepted .... as i use 1 card x16 in that lane is enough for me(Gaep45 rocks in this case)
pt5 : Not acceptable as i am talking after using the board for 1-1.5 years +
As any new decent board will give great performace upto 1-1.5 years.
So , what am i missing bro?
