Old 17-08-2010, 03:51 PM   #1 (permalink)
Default How to enable Turbo Boost in AMD 1055T?
Do we have to manually enable Turbo Boost feature of Ph II-x6-1055T?
If so, pl give step by step guidance to do so.
What is Cool n Quiet (CnQ)? Should it be Auto/Enable/Disable in BIOS?
My motherboard - MSI-890GXM-G65
OS- W7 64bit
Thanks in advance.
ysmonyog is offline   Reply With Quote
Old 17-08-2010, 09:45 PM   #2 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Re: How to enable Turbo Boost in AMD 1055T?
IMO,turbo boost is a cpu feature,and should be enabled by default.
CnQ is a powersaving feature,earlier,it used to cause problem with the Phenom proccies. Phenom II s are fine tho. Auto should be fine.
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline   Reply With Quote
Old 18-08-2010, 01:06 AM   #3 (permalink)
OS- W7 64bit
Thanks in advance.
its in Bios. need to check if its enabled.
Cool & Quite automatically underclocks the processor when in idle or when its not under load. it got a series of 2-3 points. usually at 800Mhz, 1800Mhz, ~2300Mhz. set it to auto.
Sam is offline   Reply With Quote
Buying a AMD processor Raj_Kayshap Hardware Q&A 5 15-06-2010 12:09 AM
AMD 12-core Opterons leaked ahead of launch? hot zubs Technology News 1 27-03-2010 03:58 PM
mobo for amd a2 x4 630??? The Day Walker! Hardware Q&A 3 05-03-2010 04:05 PM
AMD Athlon™ 64 X2 Dual-Core arrives !!! mohit CPU / Motherboards 2 31-05-2005 12:54 PM
