1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Photoshop, Adobe Flex and Web development.. games sometimes
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: Yes
3. What is your MAX budget?
A: 30-35 Thousand
4. Planning to overclock?
A: No
A: Windows 7
A: 40 Gb; planning to use Intel® X25-V SSD
7. What resolution will the screen run at & whats the size of the screen you want?
A: 1280*1024 (minimum); 22" inch
A: 7
A: Yes
A: in 2-3 months
A: Yes
A: Graphic card, i will add the graphic card later; on board is good for now
A: Hyderabad
A: I read a feature of gigabyte mobo ( "SATA3 storage interfaces with superfast 6Gbps link speed and RAID 0, 1, 5, 10 support".) will it enhance the performance if i choose Inter X25-V SSD ? Also, i am thinking to go for AMD processor as it will reduce the budget...
