Can you fill the below questionnaire so we can suggest you a good config!
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
a similar thread by OP started in Q&A section. please use 1 thread rather than making multiple threads that add up to the confusion of the members. thanks.
