Old 15-08-2010, 09:04 AM   #1 (permalink)
Default Temperature problem.. help needed
Guys... my friend is using DP55WB mobo with core i-5 750 processor.. He recently upgraded his 9400GT card to Amd's 5670 HD 1GB and so the psu was also changed from a local 450w to cooler master extreme series 600w.
now the problem is, even soon after the system startup the temp shown is 48-49 degrees.. while gaming it casually rises above 58 to 60 degrees.
He s using elite 310 atx cabinet so no problem of airflow.. I don think that temp is normal..why is it so ?
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 15-08-2010, 01:49 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Temperature problem.. help needed
The temperature is perfectly normal. Temperatures tend to go up to 70 degrees while gaming. However, you could put some extra fans if you are too worried about it. Put an inflow fan & an outflow fan if there is place for them.
The PSU you bought was a wrong choice. I don't know why people tend to buy the xtreme power when there are tens of other models available at similar prices, must have been the shop-keeper's suggestion. Xtreme series PSUs are as bad as local ones, though you pay much more. You should have asked in the forum before buying the PSU.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 15-08-2010, 04:54 PM   #3 (permalink)
@Cool buddy..
Are u sure the tempurature is normal.? but my system does not cross 37 degrees while idle and 52 degrees while gaming.. (you can see my signature for config.)
Is that a property of amd proccys ?
and regarding psu, we were looking only for corsair vx 550 but the cost was too much for our budget.. we were left with only cooler master option.. even fsp and zebronics pro series were also not available..
Old 15-08-2010, 05:24 PM   #4 (permalink)
Hmmmmm
Tenida's Avatar
Yes perfectly alright.Nothing to worry mate.If budget is your problem then why you have not consider Corsair Vx 450@3.7k?
Tenida is offline   Reply With Quote
Old 15-08-2010, 05:28 PM   #5 (permalink)
even if it is completely alright.. why there is a huge diff in temperature btwn his and my system ??
he was not convinced with a 450w psu..
Old 15-08-2010, 06:17 PM   #6 (permalink)
Hmmmmm
Tenida's Avatar
Talking Re: Temperature problem.. help needed
There can be temperature difference between diff.Graphics card.For example my xfx gt8600-60 degree at idle and 75 degree on load and ur frd's ati 5670 way to good for playing game as the temperature is quite low as compare to other gf cards in this category.
Old 15-08-2010, 07:05 PM   #7 (permalink)
Oops .. its my mistake of not stating wat temperature i'm talking about.. my concern is about proccy temp dude not graphics card.. even my gfx card shows 52-55 degrees when idle..
Old 16-08-2010, 12:56 AM   #8 (permalink)
Techie By Heart
mavihs's Avatar
for CPU those temps are high! case you have taken doesn't have much airflow!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 16-08-2010, 07:30 AM   #9 (permalink)
Cool Buddy's Avatar
Despite all the talks about over heating AMDs and cool running Intels, I have noticed that all Intel PCs that I have seen run hotter than the AMD PCs I have seen. I know there can be some argument about this, but I am speaking the truth, that's my personal experience.
In your case, Maybe there's some problem with the CPU HSF. Check the RPM. Also, use some additional fans, keep some space between the cabinet and a wall. Clean the inside of cabinet once a month if there is too much dust settling on it.
Not convinced with VX450W for i5+5670
sorry, i don't mean to be mean or insulting, but when somebody applies too much brain without much knowledge, they do deserve to be laughed at. I mean, people use VX450 for HD5850 + core i7. Atleast he could have read some review before spending so much money.
Nokia 5230 :(
Old 17-08-2010, 12:22 AM   #10 (permalink)
Super Moderator
asingh's Avatar
What is wrong with VX450W for i5+5670..?
asingh is offline   Reply With Quote
Old 17-08-2010, 01:17 AM   #11 (permalink)
Hmmmmm
Tenida's Avatar
giprabu's friend not convinced with vx450 he wanted some more power capable psu's like cm extreme power 600( BTW i am NT convinced) or vx550.
Old 17-08-2010, 07:31 AM   #12 (permalink)
Cool Buddy's Avatar
@asigh, exactly, that's what I'm saying. There's nothing wrong with VX450, but op's friend wasn't sure if it will be able to handle i5+5670, he wanted something more powerful. So he bought a 600W PSU that too CM xtreme power. Great decision.
The Op's friend should know that VX450 could power two 5670s in cross-fire if it were connected, without any problem, but his so called 600W PSU would not be able to power his rig without problems for long.
Nokia 5230 :(
Old 17-08-2010, 08:26 AM   #13 (permalink)
Super Moderator
asingh's Avatar
Oh heck. Groan. Sorry missed that.
Old 17-08-2010, 07:29 PM   #14 (permalink)
yep guys.. agree with all your comments about tat psu..
can u help us with that heating issue ..
BTW will corsair vx 450 be able to handle 5770 ??
Is this a power supply problem or Geforce Graphics card problem? vps85 Graphic cards 13 09-08-2010 07:36 AM
Nokia ovi music problem with windows 7 pranav.tally Software Q&A 1 07-08-2010 09:50 AM
Problem with Soundmax Audio Driver Amitava83 Software Q&A 0 14-04-2010 10:41 AM
Installing VLC in FC-6??? The Unknown Open Source 14 20-08-2007 06:39 PM
PC problem: PC starting automatically!!!??? Advice needed borg QnA (read only) 7 10-01-2005 01:26 PM
