This could be long. please bear with me.
Yesterday I attempted to switch on my PC , but it didn't start, no bootup. I opened the case , pressed the power button , got no signs of life i.e no fan spinning, no bootup . turning off and on power switch on the PSU, resulted in the fans (cpu and psu ) spinning and then stopping after a couple of seconds(again no bootup). But pressing the power button still had no effect whatsoever.
Next to check the PSu I shorted the green and black cable on the 20pin connector. It ran just fine.
Next I shorted the power button jumper, with the result that the fans started spinning, but they stopped after a couple of seconds(still no bootup).
I did a bit a fiddling around ( tried to tighten the power button jumper, removed the HDD and DVD etc) , and the next time I tried the PC booted up!
. but this didn't last for long , next time tried it didn't bootup . Since then when I press the power button , sometimes it boots , other times it doesn't boot. Sometimes it boots only after the power switched on the PSU is turned off and on
Once the system get getting hanged when my OS (xp and 7) were loading . It only got fixed after turning off the main power .
Current status is that it is working for an hour ! But I worried sick about what has happened to my pyaara . what could be the problem ? PSU going dead , mobo going bad or just moisture(heavy rainfull here) ? I am pretty sure there is no problem with HDD and DVD. gonna run a memtest now.
My temps are fine.
Pyaara PC:
AMD X2 4000+
Asus M2a-mx mobo
1 Gb corsair
Sahara 230W PSU ( I know)
Seagate 500GB HDD
Thanks for reading!
Edit; memtest ran for 1 hour without giving any errors.
