Old 14-08-2010, 10:35 AM   #1 (permalink)
Technocrat
animish's Avatar
Arrow New Monitor in 10k to 12k range HD preffered
Hi friends
can you please suggest a monitor in 10k to 12k range which support full HD and have a resolution of 22" to 24"
I have checked and found 2 monitors with HD support
1)BenQ G2412HD for around 12K
2)BenQ G2420HD for around 8K
How good are the above monitors
Also i have noticed that they have E series on their website whats the difference between the E series and G series
Also can you suggest any other monitors from any other manufacturers like AOC, Dell, Samsung or LG
animish is offline   Reply With Quote
Old 14-08-2010, 11:12 AM   #2 (permalink)
What The.... !!!
funkysourav's Avatar
Default Re: New Monitor in 10k to 12k range HD preffered
Dell u2311 IPS panel
Dell UltraSharp U2311H
blows everything else to kingdumb come
or else go for any other dell or samsung monitor under 12k,
if you are short of budget
funkysourav is offline   Reply With Quote
Old 14-08-2010, 08:36 PM   #3 (permalink)
Technocrat
animish's Avatar
Please suggest model nos. from samsung or dell as i dont know so much about monitors
& Thanks will look at the Dell u2311 IPS panel
Old 14-08-2010, 09:23 PM   #4 (permalink)
Jaskanwar Singh's Avatar
whats your use, will you game or render stuff??
Old 14-08-2010, 09:51 PM   #5 (permalink)
Technocrat
animish's Avatar
yes i will use it for gaming and watching hi-def movies
BTW how is Dell UltraSharp U2211H and come some give me its price
Old 14-08-2010, 10:08 PM   #6 (permalink)
keen to learn..
suggest any LED monitor with inbuilt tv tuner 22-24".
Hows samsung px2370?
Which web site reviews monitors well?
a2mn2002 is offline   Reply With Quote
Old 14-08-2010, 10:10 PM   #7 (permalink)
@animish
you should get Dell 23" SP2309W Full HD LCD Panel @ 14.4k
ultrasharp one is similarly priced.
Old 14-08-2010, 10:14 PM   #8 (permalink)
Technocrat
animish's Avatar
@Jaskanwar which of the both is better or both have negligible difference
Old 14-08-2010, 10:18 PM   #9 (permalink)
the dell sp2309w is a 23" monitor with more than full hd reolution and low response time, great for games and movies..
get the ultrasharp if you are in rendering as it has great colour accuracy
BTW wait for others suggestion also as my knowledge about monitors is not much
Old 14-08-2010, 10:26 PM   #10 (permalink)
Technocrat
animish's Avatar
k thanks for the suggestions i will be using the monitor like i said earlier for gaming and movies not rendering
Can anyone tell me the performance of BenQ 2200HD
Old 15-08-2010, 09:19 AM   #11 (permalink)
What The.... !!!
the dell ultrasharp series has IPS panels compared to the normal TN panels
cut the jargon
this means the colour reproduction in these monitors are phenomenal
absolutely perfect for movies,gaming,rendering,work etc
these monitors have full range 180degree display
this means that the display doesnt distort no matter which angle you are looking from any angle at all (like the crt screens of old)
trust me you wont go wrong with the ultrasharp series
the u2311h 23"@1920x1080 is available for 13,400
this is the next step in lcd technology
Old 15-08-2010, 09:31 AM   #12 (permalink)
Technocrat
animish's Avatar
Well in that case dell should be a better option for me also have read excellent reviews about dell monitors in the forum
AMD Athlon II X4 620
AsRock Ma 785GMH 128M
4GB Kingston DDR3 10600 Ram
500 GB Seagate
Corsair 450VX
Sapphire ATI Radeon 4580 1GB
Old 15-08-2010, 01:43 PM   #13 (permalink)
Cool Buddy's Avatar
Yes, me too would say the same, when you have the budget, go for an IPS panel and you won't regret.
I couldn't help but notice here, its written
What's in the Box
Monitor with stand
Power Cable
DVI Cable
VGA Cable (attached to the monitor)
that means, even if I use DVI, I cannot remove the VGA cable from the monitor!!!
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 15-08-2010, 05:15 PM   #14 (permalink)
Hmmmmm
Tenida's Avatar
Talking Re: New Monitor in 10k to 12k range HD preffered
Go for samsung B2230@8k or
samsung lavender series P2350@10.5k
Both monitor are fullhd.I am having B2230 one which is cheap and performs very well otherwise chose Dell 23" SP2309W Full HD LCD Panel @ 14.4k or samsung lavender series P2350@10.5k.
Tenida is offline   Reply With Quote
Old 15-08-2010, 05:22 PM   #15 (permalink)
Technocrat
animish's Avatar
Hmm Samsung monitors are very good in the looks department will check out the lavender series before making my decision
500 GB Seagate
Corsair 450VX
Old 15-08-2010, 07:46 PM   #16 (permalink)
Hmmmmm
Tenida's Avatar
No not only looks better its allrounder nd also performs very efficiently...
---------- Post added at 07:46 PM ---------- Previous post was at 06:08 PM ----------
For review of Samsung P2350 -Samsung P2350 23" Full HD Monitor
Old 16-08-2010, 11:28 AM   #17 (permalink)
coolsunny's Avatar
Unhappy Re: New Monitor in 10k to 12k range HD preffered
my samsung 2233sw given me display problem after 1 year 2 months of use.. Samsung service is making too much delay replacing it. I was without my system for 47 days. though they given standby monitor few days back.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline   Reply With Quote
Suggest a mobile bet 10k -12k dheeruymv1212 Buying Advice 4 30-06-2010 10:51 AM
camera in 12k range bhaskar Cameras and camcorders 2 22-04-2010 05:51 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
VIA UniChrome Pro Display Driver ver 0.8 gary4gar Open Source 19 22-12-2007 02:09 PM
All About Unicode /programming with Unicode rohan Tutorials 6 09-11-2007 11:03 AM
