Old 13-08-2010, 04:14 PM   #1 (permalink)
Default TV tuner card issue.. Pls help.
I bought a zebronics i2010 internel tv tuner card.. But forgot to look into the system requirements while buying..
The problem is i'm able to get only the video but not the audio..
There is no Audio input socket in the card.. I'm supposed to give the audio input to a sound card but i don hav one..
Wat i did was, i used a "RCA to STEREO" converter and gave the audio input to my mobo.. Took the audio output from default audio out pin from mobo and gave it to speakers.. BUT NOTHING WORKED.
Is there anyway to solve this other than selling the card.?
Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB|Logitech MK250|CM Elite 310|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|
giprabu is offline   Reply With Quote
Old 13-08-2010, 06:30 PM   #2 (permalink)
Default Re: TV tuner card issue.. Pls help.
The audio input of your onboard sound is the same as a separate sound card in this case. Connecting the audio output of the tuner card to the input of your motherboard should work.
Maybe you have the line input of your sound device turned off. Which OS are you using?
pimpom is offline   Reply With Quote
Old 13-08-2010, 09:00 PM   #3 (permalink)
Dude..I'm not giving the audio output of the tv tuner card to my mobo.. I need to give my audio input from my tv to my tv tuner card but there is no provision for it .. So i give it to my motherboard.. i now use the card only for video input..
I use windows 7 Ultimate.
Old 13-08-2010, 10:35 PM   #4 (permalink)
You didn't say anything about taking the video and audio outputs of your TV and feeding them to your computer's tuner card. You didn't mention a TV at all. Going by what you said, there was no way I or anyone else could have known what you're trying to do.
Many, if not most, internal tuner cards do not have an audio input. There's no reason to provide one unless it's a multi-function card.
If you want to capture or listen to audio signals from an external source, there's no reason to involve the tuner card. You just plug in the audio to your computer's audio input.
I repeat the most likely reason why you're not getting sound from the TV: You probably have the line input turned off (muted) in Windows sound control panel.
Old 14-08-2010, 05:36 PM   #5 (permalink)
Ya bro.. thats wat i did.. used a rca to stereo convertor and fed the audio input from tv to my mobo.. nothing was muted and checked all those options u said..
Old 14-08-2010, 05:57 PM   #6 (permalink)
If your speakers have a stereo jack input, test the audio cable and the TV audio output by plugging it directly into the speakers (i.e., without going through the computer). See if the TV sound plays on the speakers then.
Old 14-08-2010, 06:00 PM   #7 (permalink)
amazing idea..:-P how the hell it dint strike me..!!!
will try out and reply by tonight.. (but i wont be able to record that audio)
Old 15-08-2010, 12:17 AM   #8 (permalink)
Ooops.. Din work
Old 15-08-2010, 01:30 AM   #9 (permalink)
Didn't work? What does that mean? If you mean that your TV does not play directly through the computer speakers, it means either of two things:
1) The cable is broken or the jack doesn't fit quite right. I've seen several cases where the jack does not make proper contact in the socket.
2) The TV audio out is muted or somehow not giving out a signal.
Old 15-08-2010, 08:56 AM   #10 (permalink)
Your second point is very obvious to check and so ruled out..
And regarding the other, yes the pin doesnt properly fit into to the speaker's socket. But still it fits perfectly into the 'line-in' port of my motherboard.. Any way to capture that audio ??
Old 15-08-2010, 01:13 PM   #11 (permalink)
IT WORKED..!!:-P
gave the audio input to motherboard and the default line in was muted, so it dint work last time...
thanks a lot bro...
Old 15-08-2010, 05:17 PM   #12 (permalink)
IT WORKED..!!:-P
That's what I kept suggesting as the most likely cause. Anyway, glad to know it worked out.
thanks a lot bro...
You're welcome.
Need Help ! backup & restore to new memory card in 5235 abhasbajpai Buying Advice 0 06-07-2010 06:50 PM
Digital TV Tuner card query ajai5777 Hardware Q&A 0 18-04-2010 11:45 AM
Suggest a high quality tv tuner card sakthirajesh Hardware Q&A 0 05-04-2010 12:03 PM
FRONTECH tv tuner card - stuck lost - urgent help needed sincereheart QnA (read only) 8 27-08-2008 01:37 PM
Can i View TV with External TV Tuner Card & Monitor.....? Help needed satyamy Hardware Q&A 2 02-07-2007 09:21 PM
