Old 12-08-2010, 02:00 PM   #1 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Please suggest an Upgrade
I have Rs. 10,400/- from which to buy a CPU, Motherboard and 2gb Memory.
I am opting for AMD CPU & DDR 3 ram modules.
Please suggest me the best combination of these three within my budget.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline   Reply With Quote
Old 12-08-2010, 02:37 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: Please suggest an Upgrade
Athlon II x4 635 @ 5k
Biostar TA785G3 @ 3.7k
2GB DDR3 1333MHz @ 2.5k
Old 12-08-2010, 02:51 PM   #3 (permalink)
sysfilez's Avatar
not certain Biostar mobos are easily available in kolkata.
any other mobo suggestions?
Old 12-08-2010, 09:26 PM   #4 (permalink)
Wise Old Ghoul
Piyush's Avatar
then look for MSI/gigabyte 785g based mobos
they'll be around 4.5k
so u have to lower down a bit on cpu or increase ur budget by .5k
AMD athlon II x4 630 will be available at 4.5k
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 13-08-2010, 05:56 AM   #5 (permalink)
Cool Buddy's Avatar
Biostar should be available, one friend of mine has bought it recently. Check starcomp
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 13-08-2010, 11:32 AM   #6 (permalink)
@sysfilez: Ask Jindal Computers at 14/2, Old China Bazaar St. I've bought Biostar mobos from them before and am ordering two of them right now.
Proprietor: Umang Jindal
Ph: 4005 1167
Tell him Z.K. sent you. I don't use initials when communicating with the owner, but I think he'll recognise it. I don't want to publish my full name here.
pimpom is offline   Reply With Quote
Old 13-08-2010, 12:00 PM   #7 (permalink)
sysfilez's Avatar
thanks piyush, cool buddy n pimpom for the infos.
Suggest MB + Procy + RAM to run VMWARE krinish Hardware Q&A 7 09-08-2010 03:20 PM
Suggest a PSU... Swift Hardware Q&A 43 22-06-2010 10:27 PM
Upgrade plans Buzz Hardware Q&A 15 17-06-2010 12:24 AM
suggest a mouse within rs 1000-1500.. himadri_sm Hardware Q&A 4 18-05-2010 06:57 AM
PC upgrade ninad_mhatre85 Hardware Q&A 12 17-05-2010 09:59 PM
