lol okay ill fill it
btw, he has a 1GB graphics card... around 10k for that he said...
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A: Gaming
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A: yep
3. What is your MAX budget?
A: 65000
4. Planning to overclock?
A: err no...
A: Win7 (32 or 64bit depending on the ram)
A: 1TB
7. What resolution will the screen run at & whats the size of the screen you want?
A: 1440 x 900 or 1600 x 900, 22 to 24 inch
A: 4
A: assembler
A: In 4-5 weeks
A: Not really as long as it can run most future games at medium resolution atleast
A: wont need a tv tuner.. and i guess 4gb of ram will do good.
A: Bengaluru, no i prefer to purchase within blore
A: xbox 360 controller
