Old 08-08-2010, 12:10 PM   #1 (permalink)
Default Bad Sector Formed in HDD
There is a bad sector formed in my hdd,i am not able to create partition and install OS. Is there a way to remove or rectify it?
kushalvp is offline   Reply With Quote
Old 08-08-2010, 12:45 PM   #2 (permalink)
geek........
Gauravs90's Avatar
Default Re: Bad Sector Formed in HDD
Go in command prompt and type
chkdsk /f
Gauravs90 is offline   Reply With Quote
Old 08-08-2010, 12:47 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
there is no permanent solution for bad sector. It will keep increasing.
Best solution is get your hard disk replaced (if its under grantee).
ravi_9793 is offline   Reply With Quote
Which external 1TB HDD to buy ? subratabera Hardware Q&A 8 21-10-2010 09:29 AM
External HDD & Pen drive Cool Buddy Hardware Q&A 15 31-05-2010 05:32 AM
HDD gone bad any bad sector repair tool??? ranjan2001 Hardware Q&A 37 13-02-2008 06:18 PM
HDD Bad Sectors piyush gupta Hardware Q&A 5 12-02-2006 12:07 AM
HDD Bad sectors djmykey QnA (read only) 24 13-02-2005 03:27 PM
