Old 07-08-2010, 03:11 PM   #1 (permalink)
Default HDD not detected
Friends my motherboard is Asus P5Sd2-VM. I Just bought a new hdd WD 1 TB Green Edition. I use windows XP. My bios detects my both the drives but XP dosen't I mean I can't see any additional volume or drive whatsoever. I am crippled to my 250 GB segate drive.
Scrin is offline   Reply With Quote
Old 07-08-2010, 04:06 PM   #2 (permalink)
Default Re: HDD not detected
Can you see the new drive in Windows Disk Management?
If you have a third-party disk management prog like Partition Magic, see if it shows up there.
pimpom is offline   Reply With Quote
Old 07-08-2010, 05:00 PM   #3 (permalink)
first you ned to make the partition and select the file fomat like FAT32 NTFS and all sfter that only you can see the HDD in "my computer" for doing so:
Goto:
run
type "compmgmt.msc"
disk management (it's under stroage)
ther if you can see your HDD
right click on the drive
format it using NTFS and then make partitions and other...
well I hope it's visible there though
NJempire is offline   Reply With Quote
Old 07-08-2010, 06:59 PM   #4 (permalink)
Cool Buddy's Avatar
The drive might not be formatted or partitioned, that's why it's not showing up. in start>run type diskmgmt.msc and see if the drive is shown there. If yes, then partition and format it. Create one primary partition and use the rest to create an extended partition. Then create logical drives within the extended partition. You will be asked the size, choose the size wisely as per your requirements as once you have put data on the drive you cannot change the partitions without losing data.
Nokia 5230 :(
Canon IXUS 115 HS :)
Ext. HDD Problem sky90 Chit-Chat 4 29-05-2010 11:54 AM
Strange HDD problem g_goyal2000 Hardware Q&A 7 25-05-2008 08:03 PM
Hdd not getting detected in 3.5" External Casing navino87 Hardware Q&A 17 14-02-2008 03:50 PM
WD 80 gb ata hdd not detected by RH9 choudang Open Source 3 27-08-2006 10:53 AM
SWITCHING between TWO separate physical HDD drives… sincereheart QnA (read only) 9 06-08-2005 11:26 PM
