Originally Posted by vishald
@pimpom Tried changing 2 PSU. Same issue. No way that I can install
memtest86 using that motherboard as unable to install Windows. Now I have checked the memory, hdd and processor on another motherboard and installed windows. It works just fine.
Computer is not using any graphics card other than onboard one.
OK. It's certainly looks more and more like it's the motherboard. As for memtest86, you don't have to install it on that computer. It doesn't even have to involve its own hard disk at all. Here's what you have to do:
Download memtest86+ (that's the USB flash drive version from the second URL I gave earlier) using another computer.
Unzip the small file.
Plug in a flash drive (pen drive).
Run the installation prog by double-clicking it.
It will format the flash drive as a bootable drive and install memtest86+ on it.
It's a tiny program and will finish the installation in a few seconds.
Now remove the flash drive and plug it into the defective computer. You don't have to connect the HD. In fact, it's best if you leave the HDD disconnected. The test does not involve the HDD.
Then turn the computer on, go to the boot menu and choose the flash drive as the boot device.
The computer will boot and run memtest86 automatically. You don't have to do anything else except watch the screen for the test results. If everything's OK, the lower half of the screen will remain blank. If the RAM is defective, it will be displayed in red on the lower half of the screen.
It will take several minutes to complete the test. Watch the upper right-hand side of the screen. At default settings, it will run 8 different tests and then go back to test #1 in a loop until you stop it.
