Old 06-08-2010, 09:36 PM   #1 (permalink)
Team Digit
r4gs's Avatar
Default Negative scanner
I need a scanner which can scan 35mm negatives. Can't seem to find any in India.
Any suggestions?
Budget is only 5k and I can increase it only if there is no other option.
Please help.
Core i5 2400; 8gb ddrIII 1600mhz; nVidia GeForce GTX465 1gb; seagate 1tbx3; Seasonic S12D 750; MSI H67MA-E35;
r4gs is offline   Reply With Quote
Old 09-08-2010, 02:14 AM   #2 (permalink)
Default Re: Negative scanner
Film scanners are always expensive.
HP Scanjet G3110 - HP Scanjet G3110 Photo Scanner overview - HP Home & Home Office products
Or
CanoScan 9000F - CanoScan 9000F - Scanners - Canon India
Both of them scan 35mm film negatives.
Old 09-08-2010, 06:05 AM   #3 (permalink)
Cool Buddy's Avatar
I don't know if this works (haven't tried it but always had the fancy about it). Scan the film with a normal scanner and invert the colours in photoshop.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 10-08-2010, 01:31 AM   #4 (permalink)
Team Digit
r4gs's Avatar
Scanning negatives isn't that easy.
Negatives need backlighting to scan, hence the specialized negative scanners.
You do get scanner lids with an adaptor, but unless your scanner can scan at very high dpi (1200dpi isn't even close to enough), you will lose out on all detail.
---------- Post added at 01:31 AM ---------- Previous post was at 01:26 AM ----------
@ico: thanks.
a bit over my budget but i guess it can't be helped.
Negative Feedback on TDF CA50 Chit-Chat 11 23-04-2010 10:12 PM
ADF Scanner for Home Use anto_joseph Reviews 2 26-06-2008 04:40 PM
scanner wizard jojoji_jojo Software Q&A 1 15-09-2006 06:57 AM
Scanner not scanning properly - what to do...???? sincereheart Peripherals 1 24-09-2005 02:10 PM
Scanner not scanning properly - what to do...???? sincereheart Peripherals 1 20-09-2005 10:48 PM
