I am plannin to buy a quad core desktop.my config is-
P-Quad core Q8300,
MOBO-MSI P43T-C51,
Ram-2+2 GB DDR2 800MHZ,
GPU-Sapphire Radeon HD5750 1GB DDR5,
HDD-Seagate Barracuda 7200.12 1TB,
MONITOR-SAMSUNG 2233SW
PC CASE-ZEBRONIC ANTIBIOTIC.
But I cant understand,what psu I can use for this config.my budget is 3k.plz mention the psu model and price.thanks
Yep, Core2Quad is pretty outdated. Please fill the following so that we can suggest you something -
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
