Old 05-08-2010, 03:42 PM   #1 (permalink)
bajaj151's Avatar
Default Cable coding ??
Can I use same cable for connecting "PC with Beetel 110TC1 ADSL2 + Router"
& connecting "two pc's" for file sharing ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline   Reply With Quote
Old 05-08-2010, 10:15 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Cable coding ??
Mostly yes, but doesn't always work for some reason. Why don't you just give it a try? It should work, I ahve done this once. If it doesn't work, get a crossover cable, doesn't cost much
Nokia 5230 :(
Canon IXUS 115 HS :)
RJ45 not getting plugged in cable choklate_007 Hardware Q&A 0 03-07-2010 10:44 PM
Network: How to Make CROSS & STRAIGHT cable 47shailesh Tutorials 15 03-01-2008 06:07 PM
