Originally Posted by Prakash29617
Within 20 k it is almost impossible to get a rig for animation ur rig will cry when u friend work on after effects maya/max nd other softwares they need a good GPU ( to handel viewport /2.0( in maya) need atleast 4 gb of ram while working on after effects well try this but i strickly suggest you to tell him to increase his budget atleast to 40 k. in 20 k you will get
Athlon II X4 635 2.9GHz @ 4.8k
Biostar TA785G3 @ 3.7k
Transcend 2GB DDR3 1333MHz C9 @ 2.3k
Cooler Master Elite 310 @ 1.5k/ Zebronics Krish @ 1k
Logitech Multimedia Keyboard/Mouse Combo @ 0.8k
Seagate Barracuda 7200.12 500GB @ 2k
LG 22x DVD @ 1.1k
Gigabyte LC400 80+ 400W @ 1.6k
With rest of money get a 512mb 9500 gt graphic card but plz don't blame me after 6 months when this config wiill start crying when ur friend will work on after effects, maya/max .
I had mentioned that i need only cpu,gfxcard,mobo,ram,psu n cabinet
i had thought of following
Athlon II X3 < 4k
Biostar TA785G3 < 4k
CM elite 310 = 1.5k or bizli 1.2k
SAGA II 400W <2k
RAM 2.2k
so 20 - 13.5 = 6.5k
what is the cost of HD5670 ? wont it handle thease graphics application ?
