Originally Posted by rajan1311
hey hows the matrix mode on that? Is it of any use ?
Hey That is A tediuos Question and i m working On It ...
I Come to conclusion that .
Matrix Mode: Gr8 for Mp3 , not for Movie (esp 5.1 enable Movies)
Normal Mode : Gr8 for home theater , 5.1 Enable Movies
Description:
When I Enable Matrix Mode On, then I Hear sound from all speaker , the rear spk has same sound that appears from front speaker but with less intensity as compared to Front spk.
For MP3 Its Gr8!!!! (ado) as I fell I am sitting In theater listening songs Before Movie starts
But Problem arises When I Play a 5.1 Enable Movie (Bourne Identity: 720p full hd 5.1 enable dvd)
When I Make Matrix Mode enable , all spks are Load enough but as same sound Come From All spks, I cant enjoy the 5.1.
also the sound from center spk is OFF. No Dialogues in movie
But when I disable Matrix Mode
5.1 enable Movie runs as They are made , I can hear separation of sound from each Spk....
I heard Voices / dialogues from center spk too.
but Mp3 sound is Coming only from 2 spk acting as 2.1
I M confused man !!!! but enjoyed My 5.1 A Lot!!!!!
---------- Post added at 06:47 AM ---------- Previous post was at 06:42 AM ----------
Originally Posted by PraKs
@suyash_123
Are you able to connect iPOD ? Does it have one 3.5 mm connector ?
@PraKs
Ya they have Given Me 3.5mm Connector to multi channel sound converter , but lenght of that connector is too small.....
this is How it looks
