Old 03-08-2010, 05:10 PM   #1 (permalink)
Default "please insert disk into drive " problem
i have i 2gb transcend pendrive. it was working well. but now it shows please insert disk into drive, pc detects the usb. but when i try to format it ,it show there is no disk in drive. please help me out. is my pendrive gone?
jadhava15 is offline   Reply With Quote
Old 05-08-2010, 10:57 AM   #2 (permalink)
Default Re: "please insert disk into drive " problem
Yes! Have you tried it on another pc? If yes, and same result, Then it is faulty now, if it is in warranty, you can replace it from Transcend for free.
http://www.starbytecomputers.com/blog/
ramandeepsingh is offline   Reply With Quote
Nokia ovi music problem with windows 7 pranav.tally Software Q&A 1 07-08-2010 09:50 AM
Problem in pen drive abhijangda Hardware Q&A 9 08-04-2010 10:44 AM
Partition got Deleted from Hard Disk....... prateek_san Software Q&A 3 21-02-2007 02:11 PM
what exactly is a RAID hard disk ? go_gamez QnA (read only) 10 13-09-2006 08:26 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
- by bhaskar
