Old 03-08-2010, 04:59 PM   #1 (permalink)
Default Need help..........
i have a transcend 2 gb pendrive, it was working well. but for the last week , when i insert it to port it get detected , but when i try to open it , it shows a error msg, please insert disk into drive. when i try to format it , it shows there is no disk in drive. please help me . what should i do . is my pendrive gone??
jadhava15 is offline   Reply With Quote
Old 04-08-2010, 02:39 PM   #2 (permalink)
Linoob
celldweller1591's Avatar
Default Re: Need help..........
Wrong section !! Should have posted this in hardware section.
BTW ... try another post or another computer. but i really doubt its gone !
root@Celldweller#ping www.linoob.com
Ubuntu User # 31222
Linux User # 516252
celldweller1591 is offline   Reply With Quote
Old 04-08-2010, 04:01 PM   #3 (permalink)
Cool Buddy's Avatar
@celldweller1591
excuse me, which section is this???
Yes, your pen drive seems to be damaged. Take it to the shop you bought it from with the original bill. Transcend has no service center in India, so don't even try to contact them directly. Just pick up the original bill and rush to the shop. If you do not have the original bill, throw the drive in the dustbin and forget you ever had it. Since transcend offers lifetime warranty, you need to produce the bill to prove you bought it in this lifetime itself!!! :C_badmood:
Nokia 5230 :(
Canon IXUS 115 HS :)
- by bhaskar
