02-08-2010, 09:33 PM
The GameFREAK is Online
GTX 480 discussion
is gtx 480 a good card? What are usually the operating temperatures for all the games usually upto 1920X1080 with around 4x anti aliasing?
is the zotac gtx 480 amp! with zalman cooler and 2 cooling fans good? wat is the price?
also tell me some of the good 24 inch LED backlite monitors from asus, samsung, viewsonic...
02-08-2010, 10:03 PM
Re: GTX 480 discussion
gtx480 is a microwave card...to be short
02-08-2010, 10:09 PM
What The.... !!!
"microwave card" lol!
op
gtx480 is a good card in terms of performance
but bad and superbad in terms of pricing heat and power consumption
you're better off with dual gtx460(sli ed) at lesser price point
02-08-2010, 10:56 PM
not much can be discussed on this....not many own it, not many want to own it....
I wonder why u want an LED backlit monitor? Cos you got the most power hungry card in the market and wanna save a few 20 odd watts with LED backlite
02-08-2010, 11:52 PM
@jas, give some respect to Nvidia. its known as GTX480 Microwave Edition (term first coined by me myself). also a similar name went to XFX 8600GT electric stove edition (term not brought forward by me. than i was a complete noob).
BTW, rajan how is your proccy running at just 1V with so much OC? even Athlon II X4s need 1.2V to match such speed. will try it on my proccy after a week or 2.
03-08-2010, 12:42 AM
no OC bro, just running at stock speeds, will be hard for an Athlon cos of its IMC....
03-08-2010, 10:27 AM
Nvidia needs to pay sam for such a brilliant hot title.
03-08-2010, 10:30 AM
Wise Old Ghoul
there one thing about the OPs
they start the thread
make us to start a good discussion on their topic
and they vanish without a single comment
NOTE:not all OP are of same kind
03-08-2010, 06:38 PM
but that way too low. & what is IMC?
they'll strip me of everything. also i better suited with my small & cool & least power hungry card. rather than a Microwave. already have one. also at that temp, M69's fan will go poof. so no thanks.
most are. most come. post a msg & vanish. some return after a month. some never.
03-08-2010, 10:05 PM
yea, at 1V its not very stable, if i load (games) it, the system reboots, i dont do much these days on my PC anyways, just browse. For a 100% stable system, the lowest i could get was 1.06V.
The AMDs have integrated memory controllers (IMC) so the max you can prolly do is a 1.16V or so.....(guessing from other's experience)
@Jaskanwar Sing : they will probably never send sam a review sample for that title
Coming back to topic : The GF100 was suppose to have 512 shader cores right? So no GTX485 around the corner ?
04-08-2010, 12:31 PM
oh yes. so the Vxore in i* should be high. actually AMD proccies can easily withstand voltages upto 1.6V or maybe beyond. i3s & i5s die as soon as you touch 1.5V. even 1.45V is heavy.
yes but nor around the corner. not yet till they can do something about the temperature thing. if you weren't happy with 100degree C load during gaming on a GTX480, GTX485 currently will throw you a 110dgree load. for now GTX490 or 495 coming (2XGTX460 die).
15-08-2010, 02:50 PM
hi guys..
i dont want to go for ATI as it does not support Physx and does not do so well in tessellation...
Please give me your views and also the price of ZOTAC 480 AMP! edition with zalman cooler..i heard its a very cool card 20 degrees below stock cooler... According to my knowledge the AMP! is not an oven card...so please give your views and tell me the price...
also suggest cabinet whether a coolermaster 690 II advanced or the haf 922?
15-08-2010, 03:39 PM
^^ if you want GTX480, get the sheapest possible one. take oof the HFS. get a OEM GPU cooler (preferably water cooled one). & use it. total will cost you much less. or get 2 X GTX460 1Gb in SLI. done.
15-08-2010, 03:49 PM
Physx is a gimmick by nVidia, imho. It might help in some games, but most games are equally fun without it. Secondly, every card has some sort of "physics engine" in it, if not "Physx."
Go for 2 * GTX460 in SLI instead of GTX480.
15-08-2010, 05:34 PM
my motherboard does not have sli so have to go for a single card...at least tell me the price of zotac gtx 480 amp edition. so that i can have an idea wat would be the difference between this and 5870..
15-08-2010, 06:00 PM
GTX 480 is about 10% faster than HD 5870 with 40% higher power consumption and noise. HD 5870 will cost around 21.5k whereas GTX 480 costs around 28k.
Better buy a HD 5970 if you have a budget around 34k.
15-08-2010, 06:37 PM
so AMP should cost around 31-33k. so better get a basic GTX480 + a aftermarket cooler.
15-08-2010, 09:45 PM
Wise Old Ghoul
i'll recommend him HD 5870
15-08-2010, 10:18 PM
#19 (permalink)
if spending around 33k for gtx480 get hd5970 then
15-08-2010, 11:26 PM
#20 (permalink)
what about cabinet cooler master 690ll advanced or haf 922?
16-08-2010, 01:05 AM
#21 (permalink)
Techie By Heart
@OP
which SMPS you have?
go for CM 690 II Advance!
█§ ║╖ î v â ╥╥╖█(™©)
16-08-2010, 07:35 AM
#22 (permalink)
What The.... !!!
if the op has the budget for gtx480,
nothing can be better than zotac amp! version,
which is wayyy cooler than the reference "chulha"!!
but on the downside the card needs heavy ventilation(i.e. very well ventilated cabby)
since the amp! clears the heat at unprecedented speed!!
and you'll need corsair vx550 psu at least!!
16-08-2010, 08:10 PM
#23 (permalink)
hi funkysourav,
will you consider the cooler master 690 II advanced or the haf 922 as a well ventilated case?
also wats the approx price of the zotac gtx 480 amp! ?
do u own the gtx 480 amp!? if yes please give ur views on it...
and as a brand how is zotac its warranty and RMA policy..?
and yes for the psu i am going for a corsair HX 850...
