Old 02-08-2010, 04:24 PM   #1 (permalink)
my precious
Gollum's Avatar
Default How Important is a power supply?
Recently my Seagate 500Gb/32MB cache HDD died taking away most of my important data. Though I got a completely new HDD after free replacement within a week but all my data was gone. According to Seagate my HDD fell in the 0.33% of the failure rate of 500GB hard disks.
This was my secondary hard disk and did not contain my OS so the computer still boots.
This HDD was not even a year old and it died so fast. It didn't show any signs of overheating or SMART problems in everest or POST either.
Could this have been due to the power supply?
I also have another Seagate 160GB hard disk but its running fine.
System Spec:
Asus M2N VM DVI
XFX 9500GT
Zion 1GB @ 800MHz x2
SOny DVD Writer
LG combo Drive
SOme local powerr supply
Apart form this my computer never gave any hickups, I keep it clean from the inside and have a good cabinet cooling system with an external power supply to power the cooling fans.
Gollum is offline   Reply With Quote
Old 02-08-2010, 07:34 PM   #2 (permalink)
Default Re: How Important is a power supply?
The short answer to your main question is that it's impossible to say. If we concentrate on the word "could", then the answer is Yes, it could be. That's not the same as saying "Yes, it must be the power supply".
A poor power supply - not just the SMPS but also the power line, UPS, etc - can certainly cause a hard disk to fail.
Hard disks have a device to protect it against voltage spikes in the power supply line. If the spike is momentary, the device absorbs the excess voltage. If the spike is longer, then the protection device shorts out permanently, making the HDD unusable, but the rest of the drive is often still OK and just needs replacing the protective device. If this type of fault occurs, it will usually prevent the computer from turning on until the HDD is disconnected.
This is just one type of HDD failure. A hard disk is a complex device and other parts can also fail. So it's impossible to say without an on-the-spot investigation, sorry.
pimpom is offline   Reply With Quote
Old 02-08-2010, 08:32 PM   #3 (permalink)
Techie By Heart
mavihs's Avatar
which SMPS you have & wats the wattage?
which cabby you have?(just curios)
which version of Seagate HDD you had - 7200.10 or 7200.11 or 7200.12?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 02-08-2010, 09:02 PM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Actually its the same question I asked here some time ago.I ended up buying a good PSU.However I havnt had any probs using local SMPS for 4.5 years.In my old rig I had a 400W frontech (local SMPS) and it worked fine with a 9500GT .In my current rig I used a 450W zebronics (another local SMPS) still had no problems.But for safety I bought a Pro 500W.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 02-08-2010, 09:10 PM   #5 (permalink)
Jaskanwar Singh's Avatar
you can say that a psu is the heart of your pc........
Old 02-08-2010, 10:20 PM   #6 (permalink)
Cool Buddy's Avatar
PSUs are quite important as I realised after I heard of quite a few blown gfx cards/mobos etc. But the thing is, the price difference between good brands and local PSUs is so huge that it always hurts to buy a good PSU and we end up buying a local one. For instance, a local 450w PSU will cost around Rs. 400 while FSP saga II 400W costs Rs. 2000 and corsair VX450 costs Rs. ~3600. I have never seen such difference in any other component. for instance, a local mouse will cost 150 whereas a logitech PS/2 wil cost 300, just a difference of 100%. speakers will cost local 2.1 for 400, cheap creative or AL 900-1000. around 125% difference. But in PSUs it is more than 400-500% difference. But still, that's the only choice we have.
Yet, it always pays in the long run to have a good PSU coz one blown part and you end up spending much more than you saved on the PSU.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 03-08-2010, 12:18 AM   #7 (permalink)
maybe cause when you brought your local PSU (4.5yrs ago) you got a good quality PSU (lack of international PSUs here) locally. but with the easy availability of good PSU at 1.5-2k, local PSU's price came low. & to do it, is the quality.
OEM PSU manufacturers like Seasonic, FSP & a few more spend millions in R&D to get the best combo at cheapest possible price. local PSU, just hook up 2-3 pieces of aluminium foil & wrap some copper wires to make up the transformer. and a few CHEAPEST caps. & a microscopic circuit board. also the fan is 40mm in most. HECK!!! what will it cool? so efficiancy is dead low. also warranty is 6month, cause by the time its about to finish 1yr, BOOM. no PUFF (desi PSU not have enough power to even go BOOM BOOM ).
also the amount one saves by going for desi PSU over good efficiant ones, loose more money in less than 1yr. burnt PC parts, high electricity bill, blown up PSU (itself).
Sam is offline   Reply With Quote
Old 03-08-2010, 09:42 AM   #8 (permalink)
Wise Old Ghoul
Piyush's Avatar
answer to your thread name:-
the power supply to the pc is just like the air,water and food to humans
---------- Post added at 09:42 AM ---------- Previous post was at 09:40 AM ----------
i never asked anyone this question
whats the difference between 7200.10 or 7200.11 or 7200.12?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 18-09-2010, 12:07 AM   #9 (permalink)
my precious
Gollum's Avatar
Sorry for replying so late. (thought this is a no reply forum) i think it was the .12 model of hdd. Cause .12 normally means 32mb buffer.
I got a brand new replacement hdd but rashi(supplier) gave me one with 16mb buffer X(
Haven't used my comp for nearly two months now. Thinking of buying an el cheapo used laptop for watching movies.
Old 18-09-2010, 01:11 AM   #10 (permalink)
wrong info buddy. .12 drive comes with 16Mb, 32Mb & 64Mb. maybe 8Mb too but not sure.
Old 18-09-2010, 03:17 AM   #11 (permalink)
my precious
Gollum's Avatar
When i checked the seagate website they had only 3 models and the one with .11 had 16mb buffer. So i thought that might be the case.
Old 18-09-2010, 10:19 AM   #12 (permalink)
The Master Chief
Ronnie11's Avatar
Wasn't there a firmware issue some time back with the 500gb HDD of seagate..Because many had complained of High failure among 50gb HDD of seagate including mine...i lost all my data as well,they replaced it but the service guy told me it has an updated firmware or something...
Intel Core I5 2500K,Gigabyte GA P67A UD3 B3,Corsair Vengeance 4gb DDR3,CM430 Cabinet,Corsair VX550W,Razer Cyclosa Bundle,Seagate 250GB,500GB,1TB,MSI 5770 hawk
Ronnie11 is online now   Reply With Quote
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
Auto Power on your PC gauravgargi Software Q&A 2 05-02-2010 10:54 AM
Power Supply bal1961 Hardware Q&A 2 08-01-2008 11:00 PM
Getting the right Power Supply gxsaurav QnA (read only) 29 09-10-2005 02:18 PM
Should P-1 Mother Board support ATX power supply ? ssingha QnA (read only) 1 24-08-2004 10:59 PM
- by bhaskar
