Hi friends,
I'm facing a rather irritating problem.
My monitor is showing some kind of flicker/grains. I have a "Viewsonic VG1921wm 19 inch" flat panel.
- The problem started after my SMPS was busted and i got it (SMPS) replaced.
- After replacing SMPS, i realized that my graphic card too had burnt. So, temporarily, I used the onboard graphics of my "Intel DG33" motherboard. The flicker/grains started from here onwards.
- I got my graphic card replaced only to find that the slot too had burnt. Hence I got a new motherboard too. So presently I have an "ASROCK G41M" motherboard and "NVIDIA 8500GT" graphic card.
- Even after these replacements, there is still the same amount of flicker/grains.
The following are steps that I have already tried to get rid of the problem:
- Updated NVIDIA drivers
- Updated Viewsonic's monitor drivers
- Changed cable between CPU and monitor
- Changed power cable of monitor
- Tried lower refresh rates with lower resolutions (it shows up even at 60Hz and 800x600 - w.t.f)
In order to narrow down if the problem was due to monitor or CPU, I had it separately tested at a friend's place. These were the results:
- (Friend's CPU+My Monitor) The monitor displays without any flicker/grains
- (My CPU+Friend's Monitor) No flicker/grains
Also, I have tested the monitor with the projector out port of a friend's laptop and it still works fine.
Its only that my CPU + my monitor = problem.
Please someone help me. I have already invested so much in getting replacements and service charges to unsuccessful service guys. This is my only hope of getting back on my PC.
