Old 31-07-2010, 09:53 PM   #1 (permalink)
Default Operating temprature
My Cabinet's operating temprature is 35 degree celcius, when the external fan is on. Is it too high? and when i game on it it goes to 40-43. I am using HD5770 X6 1055t, and corsair vx550. Shall i attach another external fan>??
ani1751 is offline   Reply With Quote
Old 31-07-2010, 10:31 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Operating temprature
Temperatures are ok for a running PC, but what is cabinet operating temperature?
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 31-07-2010, 11:49 PM   #3 (permalink)
Super Moderator
asingh's Avatar
You are fine.
asingh is offline   Reply With Quote
Old 02-08-2010, 09:52 AM   #4 (permalink)
@cool buddy, I meant the temprature inside the cabby, not the chip....
Old 02-08-2010, 10:10 AM   #5 (permalink)
Wise Old Ghoul
Piyush's Avatar
its just ok bro
dont need to worry
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 02-08-2010, 12:16 PM   #6 (permalink)
Cool Buddy's Avatar
OK, how do you measure that?
Nokia 5230 :(
Old 02-08-2010, 07:15 PM   #7 (permalink)
^^ wanted to ask that myself as well. did he used some digital temperature recorder? or thermometer?
Sam is offline   Reply With Quote
Old 02-08-2010, 08:17 PM   #8 (permalink)
Techie By Heart
mavihs's Avatar
which cabinet you have?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 02-08-2010, 10:04 PM   #9 (permalink)
Cool Buddy's Avatar
mavihs's question gives me an idea. May be some high end cabinet have this feature of reporting operating temperature.
Nokia 5230 :(
Old 02-08-2010, 10:30 PM   #10 (permalink)
Techie By Heart
mavihs's Avatar
my old cabby - Zebronics Peace has this option(its a really low end cabby though better than Elite 3xx)!
Old 02-08-2010, 10:55 PM   #11 (permalink)
Cool Buddy's Avatar
guess we should live without that feature. no use being so paranoid
Nokia 5230 :(
Old 03-08-2010, 10:09 AM   #12 (permalink)
I have Navtech cabby. It has digital thermometer...
Old 03-08-2010, 10:17 AM   #13 (permalink)
Cool Buddy's Avatar
It's not a good idea to keep the cabinet so close to the wall, although, since temperatures are not high, it's alright. Yet, do keep a gap between the wall and the cabby. Even the paint on the wall suffers due to the constant heat radiated from the cabinet and there should be some gap at the back too.
One thing, are you sure about the accuracy of that digital thermometer?
Nokia 5230 :(
Old 03-08-2010, 11:19 AM   #14 (permalink)
Yea, I guess its accurate. Its is really temprature sensitive. When i game it goes as high as 45'C.
Old 03-08-2010, 06:42 PM   #15 (permalink)
that thermometer isn't very accurate. cause it measures temp at some definite point. one need the temperature between the graphics card & proccy. its best place to measure temp. i think OP's system don't have the provision to place the sensor at a definite place.
Old 05-08-2010, 09:29 AM   #16 (permalink)
I can, Its placed below GPU fan
Old 05-08-2010, 06:48 PM   #17 (permalink)
^^ than its a good one. a rough idea about the system temperature.
Old 05-08-2010, 09:49 PM   #18 (permalink)
Cool Buddy's Avatar
@sam.shab Please don't take it otherwise, I just mean to correct you. Look up the dictionary for the difference between thEn & thAn. They have quite different meanings. You often use than in place of then. I have seen you making that mistake many a times
Nokia 5230 :(
Old 05-08-2010, 10:11 PM   #19 (permalink)
Wise Old Ghoul
Piyush's Avatar
grammar classes in operating temp thread
--Get Backers
Old 05-08-2010, 10:32 PM   #20 (permalink)
Cool Buddy's Avatar
sorry for that, but this was probably the n-th time I saw sam making this mistake, so couldn't resist.
Nokia 5230 :(
Old 06-08-2010, 02:08 AM   #21 (permalink)
thanks a lot for pointing it you buddy. actually i really poor when it comes to grammer. and also i just go for the point of the topic. so many times mess up with the grammer & meanings. anyway thanks a lot. i'll try avoid this mistake in future
Old 06-08-2010, 12:46 PM   #22 (permalink)
Spammers are able to quote but not the regular members
Faun is offline   Reply With Quote
Computer restarts GEEKCOMPUTER_GEEK Software Q&A 6 23-06-2010 02:30 PM
Managing Multiple Linux Operating Systems paragkalra Open Source 1 06-01-2006 09:41 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
- by bhaskar
