Old 30-07-2010, 02:46 PM   #1 (permalink)
Nemes!s's Avatar
Question Advice on good PSU
Hi Guys,
I have finally placed the order for following components
AMD Athlon II 2.9 Ghz. 635 X4 @ 4.6k
WD SATA 500gb 32 MB Cache @ 1.9k
AMD Biostar ATI 785 Chipset TA785G3 HD @ 4.3k
BenQ G2220HD 22 inch with DVI n HDCP 40000:1 Contrast @7.1k
DDR III G.Skill 2 Gb F3-10600CL9S-2GBNT 1333 mhz. @5.2k
Cabinet Zebronics Bijli @ 1.1k
Sony Boxed SATA Black 24X @ 1k
KB Mouse Combo iball MM Duo Laser Black @ 800
Speaker 2.1 Altec Lansing BXR1221 @ 955
Headset with Mic Frontech 1903 @ 217
FSP Saga II 500W @2.5 (Not available) then i asked for SMPS Corsair 450W VX @.3.5k (Not Available)
Now I have 2 choice Corsair 550W VX @ 4.7k or TAGAN 500W Maxpower 600 @ 3.4K
Please suggest
Nemes!s is offline   Reply With Quote
Old 30-07-2010, 03:00 PM   #2 (permalink)
Default Re: Advice on good PSU
Go for corsair ... it worth all the money .. and actually it gives u more power than 550W ... so u will never face power trouble ... for a graphics card ( OC'ed) and more hard disks and a Oc'ed CPU ... but i think u are not buying a graphics card ..so u can go for something lower too. In case u want to buy graphics card later on .. Corsair 550W will be better choice ..
chilling.....
imgame2 is offline   Reply With Quote
Old 30-07-2010, 04:36 PM   #3 (permalink)
Cool Buddy's Avatar
If you think you'll be adding a good gfx card later on, then buy the corsair. otherwise order FSP Saga II 400W online. fixing a PSU is easy in case you are worried about that.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 30-07-2010, 06:39 PM   #4 (permalink)
Nemes!s's Avatar
Thnx imgame2 and cool buddy for advice
imgame2 and others adviced...I will buy Corsair vx550 little costly though ;-(
Old 30-07-2010, 08:53 PM   #5 (permalink)
Jaskanwar Singh's Avatar
my vote to vx550 but isnt vx450 available...
Old 31-07-2010, 08:47 AM   #6 (permalink)
Even though its looking costly now but its very efficient and thus will save ur electricity bills and any harm to other computer components ...
I have corsair vx 450 .. and it works amazingly fine ...
Another thing is that there are two kinds of Power supply specification .. one is Peak Power Rating and other is Continuous Power Rating
Most of the other manufacturers always mislead by specifying Peak rated power supply .. which is the maximum power PSU can supply which can be achieved in ideal circumstances .. which is the case with most of the low cost PSU which rates power supply as 400W. While Corsair always rate PSU as Continuous Power rating which it can supply all the time .. infact a corsair VX450 can supply about 500W of continuous power .. so corsair under rates the PSU .
i believe U should know why u are buying something.
u can fine more info on PSU here :- http://www.neowin.net/forum/topic/88...r-supply-unit/
chilling.....
Old 31-07-2010, 08:36 PM   #7 (permalink)
Nemes!s's Avatar
Hi
I just assembled my pc but it is not starting... i checked the power and psu switch is on..still nothing is working...psu fan is also not running...any idea what may be wrong ?
Old 31-07-2010, 10:16 PM   #8 (permalink)
Cool Buddy's Avatar
Which PSU did you buy?
If the PSU fan is not running, either the PSU is not working or the main power cable is damaged. Try changing the power cable with the one you have plugged into the monitor before you try anything else.
Nokia 5230 :(
Old 01-08-2010, 01:55 AM   #9 (permalink)
Nemes!s's Avatar
i bought corsair vx550w... i checked everthing but still not wrokin..i will reassemble the pc again tomo
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
Need suggestion for PSU Cilus PC Components / Configurations 12 06-03-2011 11:23 PM
Buying a new pc, need advice mumblehere PC Components / Configurations 41 26-09-2010 02:18 AM
Good WIFI N series router abhinav_bipnesh Hardware Q&A 7 28-06-2010 09:40 PM
how good are MICROMAX phones andy_65_in Mobiles and Tablets 0 16-04-2010 09:50 AM
- by bhaskar
