Old 30-07-2010, 12:01 PM   #1 (permalink)
Default Suggest a laptop under 55k
Hi, please help me in choosing a laptop at 50k-55k. I want the following minimum configuration-
1) Core i5 or i7 processor
2) 15"-16" Full HD LED Screen
3) 4 GB DDR3 RAM
4) 500 GB HDD
5) A decent graphics card. I don't need very high FPS at full details in the heavy games. The games should just be playable. I had a Nvidia 8600GT (256 mb GDDR3) in my desktop with a 15" monitor, C2D 2.2 GHz procy, 3GB DDR2 RAM. It will suffice if the laptop provides the same gaming performance.
6) Looks is of little importance. So i prefer a Vaio or Dell over an Acer. But if an Acer provides a much higher config at that price than its ok. I dont know much about other brands like Asus, MSI, Toshiba regarding laptops.
Thanks guys. Please help me choosing a laptop for the above mentioned config.
bhaskar is offline   Reply With Quote
Old 02-08-2010, 07:19 PM   #2 (permalink)
Default Re: Suggest a laptop under 55k
I will recommend you to buy a Acer 4820TG Laptop
Specification:
Processor: Intel Core i5-430M 2.26 GHz 3MB L3 cache, Display: 14" HD, RAM: 4GB DDR3, HDD: 500GB, Optical Drive: DVD Writer, Graphics Card: ATI Rad 1GB, Speakers: Dolby Stereo Speakers, LAN: GigaLAN, WiFi: Yes, In-built Webcam: 1.3 Megapixel, Card Reader: MultiCard Reader, Bluetooth: Bluetooth 3.0 HS, USB Port: 4 x USB Ports, Battery: 6 Cell, Battery Life: 8 Hours Battery Life, Operating system installed: Windows 7 Home Premium
tboss is offline   Reply With Quote
Please suggest a laptop rahulbatra69 Laptops and Netbooks 3 22-07-2010 08:54 PM
suggest laptop at rs 25-30k phuchungbhutia Laptops and Netbooks 2 12-07-2010 08:01 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
- by bhaskar
