Old 29-07-2010, 07:52 PM   #1 (permalink)
Default Are quad core processors good for gaming?
i want to buy a new processor around 6ks
which one is the best deal for gaming??
gamemperor is offline   Reply With Quote
Old 29-07-2010, 08:49 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: Are quad core processors good for gaming?
Please be more specific by telling your system configuration and wether you plan to buy both motherboard and processor or only processor
Cybertonic is offline   Reply With Quote
Old 29-07-2010, 09:48 PM   #3 (permalink)
Jaskanwar Singh's Avatar
yup, tell your whole system config..
Old 29-07-2010, 10:28 PM   #4 (permalink)
Go with higher clock speed Core2Duo for normal games;
If you want to play latest DX11 games than go with Quad..
Zishi is offline   Reply With Quote
Old 01-08-2010, 08:16 PM   #5 (permalink)
aah my PC is a Antique **** box xD ^^...
p4 2.66 ghz
1 GB DDR ram @_@
and a screwed up intel mobo =__=
has no graphic card
well yes i will have to buy a mobo too....[cuz the current one jus wont support the new thingz]
so do suggest me a mobo around 4ks which is compatible with processor u mention xD ^^
and if the mobo u suggest runs DDR3 RAM then plz temme how much it will cost to get a 1 or 2 gb stick
THANX in Advance guyz
Old 02-08-2010, 08:30 AM   #6 (permalink)
can you tell your whole budget??
---------- Post added at 08:30 AM ---------- Previous post was at 08:28 AM ----------
there is no such thing...dx11 games can be played on dual cores also...you need a dx11 gpu
Old 02-08-2010, 06:43 PM   #7 (permalink)
well 6 for the proccey and around 4 for the mobo so tat gives around 10ks
and will buy new stick of ram by selling[plus adding a bit by ma side] the one m havin now xD @_@
Old 03-08-2010, 12:43 AM   #8 (permalink)
get this:
Athlon II X4 630/635.
Biostar TA785G3 HD.
total will be @ 9k & will play almost any game you throw at it, provided its backed by 2Gb or more ram. with the extra 1k, add 1.5k (by selling your old parts, adding extra cash) and get a single stick of DDR3.
Sam is offline   Reply With Quote
Old 03-08-2010, 10:06 AM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
athlon II X4 630 is avb @ 4.4k and 635 @ 4.9k
MSI 785g is avb @ 4.6k and 880g @ 5.6k
so make up the combination as u like
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 07-08-2010, 07:34 PM   #10 (permalink)
i have heard that MSI mobos come up with many probs related to bios and other stuffs.....
mahn what should i do @_@.....
and is buyin a biostar mobo worth ??
Old 07-08-2010, 08:02 PM   #11 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Are quad core processors good for gaming?
I've bought a MSI mobo with AMD Athlon X3 Processor for my dad and it's working perfectly fine without any kind of BIOS related problems as you said. There's nothing to worry about MSI mobos, go for them.
debsuvra is offline   Reply With Quote
Old 07-08-2010, 08:41 PM   #12 (permalink)
you are using that mobo since ??
---------- Post added at 08:08 PM ---------- Previous post was at 08:04 PM ----------
btw tat biostar mobo is quite cheap and offers almost everything i need.....the only con is it has only 2 memory slots.
m reading the user reviews of biostar and all i got is tat they are quite good.
---------- Post added at 08:41 PM ---------- Previous post was at 08:08 PM ----------
howz this mobo
Newegg.com - BIOSTAR TA870+ AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard
Cons: No integrated graphics.
that means???
please shed some light U_U
Old 07-08-2010, 09:10 PM   #13 (permalink)
Wise Old Ghoul
Piyush's Avatar
i'm using MSI too
no problem so far
and there will not be any of them in future
thats for sure
--Get Backers
Old 07-08-2010, 11:56 PM   #14 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: Are quad core processors good for gaming?
that means???
That means the motherboard doesn't have integrated graphics and you need to add a dedicated graphic card to it. Simple.
Processors Help Needed rohit2hell PC Components / Configurations 12 28-07-2010 02:37 AM
decide between intel core2 duo or phenom amd quad core Dr Mohit Hardware Q&A 3 28-05-2010 06:57 PM
[Urgent]Looking to buy good Flashdrive/Pendrive (16GB or above) kanishka Hardware Q&A 7 31-03-2010 07:26 PM
Please help me in choosing a Good Circumaural Headphone emmarbee Audio 0 03-02-2010 04:01 AM
AMD's Phenom X4 9850 gets pitted against Intel's Core 2 Quad Q9300 DigitalDude Technology News 28 14-10-2008 07:26 PM
- by bhaskar
