Old 29-07-2010, 06:02 PM   #1 (permalink)
Post new computer
hi ia m venkat,going to buy a new computer for working on maya and compositing tools ,so i chosen following configuration,but before buying i think its best to ask tech guys help, thats why m here...
and i need costs also...kindly plz help me
and configuration is,....
1.asus p7p55d-e mother board,
2.intel i5-750 processor,
3.gtx 260graphic card,
4.ddr3 4 gb ram(2 x 2)
5.samsung 22' monitor
6.500gb hdd
7.cooler master's elite 310 with 650w smps cabinet
8.22x dvd writer
9.mouse and keyboard logitech
10.1 kv ups
:-Pvenkat
venkataramana1987 is offline   Reply With Quote
Old 29-07-2010, 06:44 PM   #2 (permalink)
Default Re: new computer
lol that last line cracks me up
---------- Post added at 06:44 PM ---------- Previous post was at 06:42 PM ----------
i5 750 ~9.5k or get i5 760 ~10.5k
APC 1kV UPS ~4.7k
get corsair VX450 for ~3.7k or VX550 for ~4.8k
Mouse and keyboard combo logitech Rs. 650/-
500GB HDD ~3k
Faun is offline   Reply With Quote
Old 29-07-2010, 08:36 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
Please fill this -
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
Cybertonic is offline   Reply With Quote
Old 02-08-2010, 09:52 AM   #4 (permalink)
Smile Re: new computer
Originally Posted by Cybertonic View Post
Please fill this -
A:mya,comopsiting and photoshop
A:yes
A:50,000
A:no
A:either xp64 or windows 7
Arimarily 320 later it would be 600 gb or more
A:22'
A:7
A:yes i did
A:right now
A:yes.! absolutely
A:no
A:visakhapatnam,andhra pradesh probably better i could
A:
hi cybertonic i filled this can you see this plz?
---------- Post added at 09:52 AM ---------- Previous post was at 09:48 AM ----------
APC 1kV UPS ~4.7k
500GB HDD ~3k
hi thanks for the reply....can u tell me what si deiiference b/w 750 and 760 ....plz let me know detailed
Old 02-08-2010, 10:29 AM   #5 (permalink)
750(2.66 GHz) is replaced by 760 (2.8GHz) now. Its just higher frequency nothing else.
Old 02-08-2010, 10:42 AM   #6 (permalink)
Wise Old Ghoul
Piyush's Avatar
so does that mean 750 is no more in the market?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 02-08-2010, 11:22 AM   #7 (permalink)
You can get it but the new default is 760 now.
Old 02-08-2010, 07:24 PM   #8 (permalink)
750 should be available at 9k or less.
Sam is offline   Reply With Quote
Old 02-08-2010, 08:26 PM   #9 (permalink)
Techie By Heart
mavihs's Avatar
2.intel i5-750 processor, - not good enough for rendering (go for AMD 1055T)
3.gtx 260graphic card, - old/outdated
4.ddr3 4 gb ram(2 x 2) - which???
6.500gb hdd - which one where you planning to for for Seagate or WD? ( i suggest go for WD 500GB Blue)
7.cooler master's elite 310 with 650w smps cabinet - just bad (go for Elite 430 atleast. & never go for bundled SMPS! instead go atleast for Corsair vx450)
8.22x dvd writer
10.1 kv ups
:-Pvenkat
good thing you asked us coz the above config isn't good!
tell us will you be playing any games on this system?
go for an AMD based RIG!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 07-08-2010, 12:19 PM   #10 (permalink)
hi shiva....
thanks for the reply and actually my budget is 55,000...according to the shop i asked once they gave all these at that cost,so i chosen this....according to you if amd 1055t available at 900 and supports lga1156 socket ...ok no problem,and ram i chosen is zion,
cooler masters elite 310 and 430 are 1900/- and 3000/- respectively,
thats not such diff b/w seagate and wd
excepting all these u can even suggest me, that suits my budget and needs...
about ur questions----i m interested about only nfs and chess ,so games not limits 2hr /day,,,only sitting on 3d and compositing
:roll:
Old 07-08-2010, 04:15 PM   #11 (permalink)
Techie By Heart
mavihs's Avatar
hi shiva....
:roll:
have you already bought RAM, cabby & Mobo?
Old 07-08-2010, 04:29 PM   #12 (permalink)
hi shiva
no no even the one part i didn't buy.....i have to buy whole setup once...that's why i m waiting
Old 07-08-2010, 04:42 PM   #13 (permalink)
Techie By Heart
mavihs's Avatar
just want to know some more thing before i recommend a config!
are you working or studying Animation?
which all apps are you going to be using i.e. Maya, 3D Max, etc?
Which render are you going to be using i.e. Mental Ray, etc?
which part are you specialized/specializing in i.e. light, texturing, rigging, etc?
Old 07-08-2010, 04:42 PM   #14 (permalink)
hi shiva....
:roll:
no. X6 1055T will cost you close to 10k or maybe tad more but as mentioned 3D & animation, it'll be better for you. also socket is not LGA1156. but AM3. but i don't think it matters much. just change as mavihs suggested. go with retiers suggestion if you want a old, bad & costly (totally out of balance) config. so for motherboard, get something based on 880G or 870X or 890GX based one. features more than the ones you get on the LGA1156 motherboards at lesser pricing.
Old 07-08-2010, 05:59 PM   #15 (permalink)
m currently working as compositor,mattepainting artist.at spot now i have to buy computer ibn this month and now have only 55,000
and i use nuke.maya. fusion. photoshop, aftereffects,
my specialization is texturing
thanks shiva
---------- Post added at 05:59 PM ---------- Previous post was at 04:52 PM ----------
hi sam....thanks for valuable info.........and i hope u can give me such quote at 55,000 along with graphicard.........plz help bcoz this is matter money,and asus m4a89gtd is ok and x6 1055t is around 10000/- right and what graphic card is better then,and i dont know what is good cabinet at this budget
Old 07-08-2010, 06:57 PM   #16 (permalink)
Techie By Heart
mavihs's Avatar
Proccy: AMD 1055T - 10.5K
Mobo: MSI 890GXM-G65 - 7.5K
RAM: GSkill Ripjaws 4GB Kit 1333MHz CL9 - 6.3K around
HDD: WD 500GB Blue - 2K
GPU: ATI FirePro V3800 - 8K around / 460GTX 1GB(get this if you can) - 14K around
Cabby: Elite 430 - 2.7K
SMPS: Corsair vx550(this should be good for your future needs) - 4.8K / Corsair vx450 - 3.7K
---------- Post added at 06:57 PM ---------- Previous post was at 06:55 PM ----------
PS: this is the minimum you should go for, for a decent performance!
Old 08-08-2010, 12:40 AM   #17 (permalink)
no problem friend. but as mavihs already gave a config so i won't repeat it again. but still lets see if i can offer my help.
ok let me edit your config:
Processor: Phenom II X6 1055T 2.8GHz @ 10-11k
Motherboard: lets take a basic one. Gigabyte GA-MA785GMT-US2H @ 4.5-5k.
Ram: Corsair 2X2Gb DDR3-1333Mhz Value @ ~5k
Graphics Card: -
PSU: Corsair VX450W @ 3.6-4k
Cabinet: Cooler Master Elite 310 @ 1.5k
Hard Drive: Wester Digital 500Gb Blue @ 2k
Total: 26.6-28.5k.
whats left?
Monitor: get a 20" from Benq or Dell @ 6.5-7k (22" will affect the whole config)
Keyboard-mouse: Logitech @ 0.7k
OM: DVD writer (any) @ 1k
UPS: APC 1Kva @ not know. say 4k (can go for 650VA @ 3k)
Total: 12.2-12.7k
Grand Total: 38.8k-41.2k.
so you left with an extra 16.2-13.8k (14-16k). now as i not have much about Pro Cards, so i think mavihs or someone else can recommend the card.
PS: i think this config not bad if it gets the work done for OP without causing any problems like overheating or unable to accomodate the card well.
Old 09-08-2010, 11:08 AM   #18 (permalink)
Graphics Card: -
Total: 26.6-28.5k.
whats left?
Total: 12.2-12.7k
thnks for u both guys helping me alot......\o/
from ur suggestiions now i selected
processor: amd phenom II x6 1055t-------11,500
mobo: biostar ta89gxe -----------6500
gpu: msi geforce gtx470 graphic card---13000
ram: corsair 2x2----------------------4800
cabinet: elite 310 --------------------1900
psu: corsair 650w ----------------4000
monitor: samsing 22"------------------8500
hdd : wd blue-------------2000
keb&mouse: 700
writer: lg ------------------1100
ups: microtech 1 k---------3000
total isapprox----------------57,000....ho about this?
Old 09-08-2010, 11:32 AM   #19 (permalink)
change the UPS to APC. 1 k costs around 4.7k.
Old 09-08-2010, 11:32 AM   #20 (permalink)
i just saved u Rs 1000
CPU | Mobo | Ram : AMD Phenom II X6 1055T Thuban 2.8GHz - 10500/- Shipped
also, GTX 470 is not 13k, its the GTX 460 768MB version which is 12k, which is a decent choice, but i doubt it helps in rendering apps, mavihs?
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 09-08-2010, 05:39 PM   #21 (permalink)
Techie By Heart
mavihs's Avatar
keb&mouse: 700
your pricing is way off! 1055T - 10.5K, RAM is going to cost you around 6K & Corsair SMPS going to cost you a lot more around 7K the one you have listed above!
Don't go for Elite 310 & GTX470 you'll have huge temp probs! rather go for Elite 430 & GTX460!
GTX460 1GB version is for 14K!
its going to help in Viewport & AfterEffect! Also soon there are GPU based render coming from mental images(the creator of mental ray)! the first version which is going to come out will be CUDA based, after that which comes out will be OpenCL based!
Edited!
Last edited by mavihs; 09-08-2010 at 08:08 PM. Reason: Wrote something partically wrong!
Old 09-08-2010, 07:03 PM   #22 (permalink)
i dont see how you can all the difference in performance huge...? any benchmarks?
Old 10-08-2010, 09:56 AM   #23 (permalink)
my confusion stars^ day by day
Old 10-08-2010, 11:37 PM   #24 (permalink)
The Assassin
Cybertonic's Avatar
What happened to NZXT Gamma? And go for gigabyte 880g @ 4.5k
Old 09-09-2010, 09:28 PM   #25 (permalink)
Post Re: new computer
at last i went for
asu p7p55d-e-lx
intel i5-760
sapphire hd 5770
dell 22"
sony dvd writer 22x
transcend 2x2 gb ddr3 ra
seagate 500 gb hdd
cooler master 310 cabinet and 600w coolermaster smps
1 kv intex ups
microsoft k/m
53750/-
Old 09-09-2010, 09:32 PM   #26 (permalink)
Wise Old Ghoul
Piyush's Avatar
nice rig
congrats
but is it cooler master extreme PSU???
--Get Backers
Old 09-09-2010, 09:33 PM   #27 (permalink)
Jaskanwar Singh's Avatar
congrats. but which is that smps? is it extreme power??
same time i posted as you piyush baba.
Last edited by Jaskanwar Singh; 09-09-2010 at 09:34 PM. Reason: Automerged Doublepost
Old 09-09-2010, 09:36 PM   #28 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^yup
u didnt reply yesterday
--Get Backers
Old 09-09-2010, 09:36 PM   #29 (permalink)
reply to what?????
Old 09-09-2010, 09:38 PM   #30 (permalink)
Wise Old Ghoul
Piyush's Avatar
that boring time stuff.....
--Get Backers
Computer Not hibernating rohitshubham Software Q&A 6 26-06-2010 10:06 AM
Computer restarts GEEKCOMPUTER_GEEK Software Q&A 6 23-06-2010 02:30 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
- by bhaskar
