Old 28-07-2010, 02:36 PM   #1 (permalink)
bajaj151's Avatar
Default Monitor Light blinking BUT No display
Already done :-
1) Clean the Ram slots, then Insert Ram.
2) Tried New Ram
3) Remove the CMOS battery
4) Check with other monitor
5) Tried with other power supply
6) Remove connection from HDD, DVD Drive
--> I tried connecting Monitor without connecting it to CPU and monitor is displayng message : No display
That means, Monitor is fine ...there is problem with Motherboard.
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline   Reply With Quote
Old 28-07-2010, 03:43 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Monitor Light blinking BUT No display
What is the system configuration.
asingh is offline   Reply With Quote
Old 28-07-2010, 03:57 PM   #3 (permalink)
bajaj151's Avatar
Intel Board,
P4
80 GB ATA
DVD-RW
Intex 300W SMPS
Old 28-07-2010, 04:21 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
When ur PC boots do u get to see CPU light blinking or the PC does not boot at all?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 28-07-2010, 04:27 PM   #5 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
maybe asigh wanted to know if you have any graphics card or not (not onboard)...
as your point# 4 says that you have attached another monitor to your PC and it is still not working means that something wrong with the configuration...
are you able to see the bootup screen...if yes go into bios setup and try to see if HDDs are being correctly detected...you can check other critical parts too...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 28-07-2010, 04:34 PM   #6 (permalink)
bajaj151's Avatar
Yes..CPU light is blinking
---------- Post added at 04:34 PM ---------- Previous post was at 04:32 PM ----------
NO Graphics Card...
Not able to see bootup screen...
Old 28-07-2010, 04:47 PM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
@OP, please refer this thread...
No Display... System booting and shutting down properly.. SOS!!!
HD WLED Glossy display vs. 720p WLED display pranav_is_cool Hardware Q&A 3 24-06-2010 07:41 AM
Display problem - corruption, lines, video blinking g_goyal2000 Hardware Q&A 5 05-04-2010 05:40 AM
UBUNTU display drivers tech-layman Software Q&A 0 18-02-2010 11:56 AM
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
- by bhaskar
