Old 28-07-2010, 02:02 PM   #1 (permalink)
Default HDD Problem
I have a 80 GB and a 40 GB HDD on a Mercury 845GV Motherboard with 1 GB (512 x 2) Hynix RAM. Recently I installed the trial version of "AutoRun Pro Enterprise II" and after a week uninstalled it and restarted my PC and my HDD partions show up as CDROM. I can access the partitions by double click to open, but would like to get back the HDD icons and names. I have named the partitions as WinXpsp3 C:, Docs D:, Dump E:, AV F:, Images G: and Misc H:. How to do it ?
Pra1971 is offline   Reply With Quote
Old 28-07-2010, 02:30 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: HDD Problem
check if there is any autorun.inf file(hidden) in each drive.. and delete it.. see if it changes..
if not u can change icons in folder options (file types tab). replace the current icon with drive one.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 28-07-2010, 05:44 PM   #3 (permalink)
No autorun.inf file in any drive, checked that and also scanned with malwarebytes antimalware. Icon in file types is also ok. One more problem has come up, now when i double click on any partition it does not open up, but when i right click and then choose open it does.
Old 29-07-2010, 12:15 PM   #4 (permalink)
khmadhu's Avatar
autorun.inf file will be system hidden (check once again..)
open cmd
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
repeat for all the drives &
restart the pc
or in simple way try this
1Open Start >> Run and type regsvr32 /i shell32.dll
2. press ok
3. You will see a message DllRegisterServer and DllInstall in shell32.dll succeeded
Old 30-07-2010, 09:10 PM   #5 (permalink)
open cmd
restart the pc
2. press ok
Thank you the "regsvr32 /i shell32.dll" now allows the drives to open on double click but the icon problem still persists even after restart. And "autorun.inf" file still not seen in any drive.
Manufacturer HDD creating Problem!!! tiwarisatyadeep Software Q&A 0 30-05-2010 12:17 PM
Ext. HDD Problem sky90 Chit-Chat 4 29-05-2010 11:54 AM
Ubuntu 10.04 "Low Graphics Mode" problem after update krishnandu.sarkar Open Source 6 23-05-2010 05:35 AM
problem with 16GB Cruzer micro rohit330 Hardware Q&A 3 16-05-2010 08:59 PM
Strange HDD problem g_goyal2000 Hardware Q&A 7 25-05-2008 08:03 PM
- by bhaskar
