Old 27-07-2010, 11:25 AM   #1 (permalink)
Off Hook!
v.Na5h's Avatar
Default PC Buying help at Lamington!!!
this is what i have considered--
(This config is FINAL no further suggestion)
Core i3 (please no x4 or phenom 555 here ...i have already considered that)
Gigabyte GA-H55M-UD2H
G. Skill F3-10600CL9S-2GBNT 2GB 1333MHz DDRIII
1 TB Seagate 7200.12
CM Elite 310
FSP SAGAII 350w
Sony Optiarc AD-7260S / Samsung 24x SH-S243D(if available)
KB/Mouse combo - help me decide (combo strictly under 1k as low as possible)
No monitor and gfx card for now
guys i dont want to waste time asking for quotes
iam planning to get every thing from one shop
i need suggestions for shop which offers discounts on full pc purchase
pl guys also inform me about things i should look for(i mean batch codes, mb revision, oem etc etc and other intricacies involved ) before purchasing
Core i3 530 @ 2.93Ghz | Kingston 4GB (2GBx2) DDR3 1333MHz | Gigabyte GA-H55M-S2H | Acer S231HL 23" LED Monitor | Nvidia GTS 450 | Seagate Barracuda 1TB | FSP Saga II 350w | CM Elite 310 | | Philips HTS 5.1 SP100
| Zotac GTS 450 |X360 Gamepad |
Dell XCD35 powered by CM9, Soundmagic PL11 earphones, Samsung class 6 16GB
TV Shows / Movies .....I have watched....
v.Na5h is online now   Reply With Quote
Old 27-07-2010, 11:30 AM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: PC Buying help at Lamington!!!
Get a FSP Saga II 500W @ 2.7k, to make room for future upgrade. IMO, Getting all the parts in one shop, thats not a good idea. While i purchased my rig here in Chennai, i bought parts separately from many shops. Coz one got the good deal for mobo, other one for proccy. This way you get a total good deal.
But, if you get a good deal for all @ one shop, you're damn lucky man.
Logitech KB/Mouse @ 900 bucks
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 27-07-2010, 11:49 AM   #3 (permalink)
Off Hook!
v.Na5h's Avatar
^^ stricly on tight budget
i wont upgrade my pc atleast for 5 years...
even if i plan to get a gfx card(thats a rarity) i would be a a 5670 or gt 430/440 maybe even 420 or 410 if nvideo releases them..lol
i mean low end ..low power consumption ones
Old 27-07-2010, 11:53 AM   #4 (permalink)
Excessive happiness
Its just a 500 bucks more for 400W and you're good to go. Even if you buy a 5670, you need a 400W PSU at least.
PS Request
Old 27-07-2010, 11:57 AM   #5 (permalink)
Jaskanwar Singh's Avatar
Get fsp saga 2 400w @ 2k
if u want to use this pc for long, i would say athlon 2 x4 635.
Old 27-07-2010, 12:00 PM   #6 (permalink)
Off Hook!
v.Na5h's Avatar
Originally Posted by rajkumar_pb View Post
Its just a 500 bucks more...
thats the way i ended up 6 months ago with
i5 750 (Its just a 500 bucks more than X4 955 BE)
24" monitor (Its just a 3000 bucks more than a 22" incher)
and my dad rejected it!!
---------- Post added at 12:00 PM ---------- Previous post was at 11:59 AM ----------
hey i esp. edited my post regarding this....
Old 27-07-2010, 12:06 PM   #7 (permalink)
Excessive happiness
Wish you best of luck, to get all in one. Lets wait till someone know a lot about Lamington road to suggest you some shops. Bye then
PS Request
Old 27-07-2010, 12:16 PM   #8 (permalink)
Off Hook!
v.Na5h's Avatar
already know of some shops
mahavir, mccann, prime and itwares
i need suggestions regarding other stuffs involved like batch codes, mb revision, oem, bills and stuff etc etc
i mean what things must be checked before buying
Old 27-07-2010, 01:04 PM   #9 (permalink)
Excessive happiness
Only check for bills, warranty, package, and regd mobo, i hope the revision is clearly written in box. So no need to worry about that.
Also check for service centres nearest to you, so that its better for you in case of RMA. Go for itwares or Prime ABGB.
PS Request
Old 27-07-2010, 02:01 PM   #10 (permalink)
Off Hook!
v.Na5h's Avatar
BTW Guys
Check this link out
FSP >> PC Power Supply >> ATX 12V ver.2.3 >> APN,(85)
the 350w version has a dual rail 12v of 16a
and the 400w version has a dual rail 12v of 17a
so can i add a 5770 on this psu
i calculated using the outervision calc that without gfx card
my wattage(at 100% load and 40% ageing) comes out to be
Minimum PSU Wattage: 181 W
Recommended 231 -this is 50+ of 181(which is the actual load)
add tdp 108 to 181 =290w
the guy at guru3d says the it requires 40a
and now 500w ones gives 18+18 =36a
in that case even a 500w saga II will not suffice
source:
Radeon HD 5770 review
NOTE: 1. firstly getting a gfx card is a rarity coz if my dad sees me playing games he would kick my ass leave alone asking money for gfx card
2. secondly even if i get one ...considering 5770 as mostly i would buy gfx card below it i mean 5750,5670 or gt 430/ 440
Old 27-07-2010, 02:08 PM   #11 (permalink)
Fullbring
Zangetsu's Avatar
i ur dad dont allow u to play games then dnt buy it....for wastage....
the core-i3 & H55 is enuf for HD Video playback
Old 27-07-2010, 02:55 PM   #12 (permalink)
Off Hook!
v.Na5h's Avatar
no iam not getting the gfx card i just wanted to make sure that the psu should be sufficient even if i change my mind
Old 27-07-2010, 05:32 PM   #13 (permalink)
i5 750. 24" LCD + no graphics card = no display. forget games.
won't suggest change anything, but saying is you shooting in your own leg. with a dual core proccy, i doubt you'll be able go for 3 yrs.
written as code. so not easy figure it out. all OP need check is the seal not broken in any of the items.
Shops at Lamington Road.(Where to buy frm) blagame Hardware Q&A 29 18-05-2012 12:24 PM
Worth buying Dell Inspiron 15R Laptop (T540506IN8) bajaj151 Hardware Q&A 13 26-05-2010 07:19 PM
Buying a Digital Camera jackal_79 Cameras and camcorders 14 22-04-2010 05:47 PM
Help in buying Wireless router !!!!!! 047 Hardware Q&A 2 30-03-2010 05:51 PM
Buying a new PC... need suggestions! rahul941400 Hardware Q&A 24 18-02-2010 04:21 PM
- by kool
- by ax3
