Old 26-07-2010, 03:53 AM   #1 (permalink)
Post UPS Problem
well some days ago started to face a peculiar problem from my ups. It sometimes provides me with backup and at other times it does not, especially while playing games or when the computer has been on for a long duration.
I recharged it a numerous no. of times to gain the battery backup strength but still the problem exists.I am living in an area where power failures are a normal event.So, please help me figure out why does it happen.
ivanpatro2000 is offline   Reply With Quote
Old 26-07-2010, 10:59 AM   #2 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
Default Re: UPS Problem
How old is your UPS? The UPS batteries mostly die after 2-3 years of usage. Mine did.
A battery vendor said that he will repair it but he just kept on charging overnight after which it gave sound backup...but once discharged it again started behaving abnormally. Kicked it out and replaced with a new one...everything's is fine now
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 26-07-2010, 09:15 PM   #3 (permalink)
its just 11 months old.it provides good backup at times.it doesnot provide me backup when the computer has been on for a long time say an hour or 2 or while playing games.be it any
Old 26-07-2010, 09:23 PM   #4 (permalink)
vwad's Avatar
Location: Why ? Are you coming for dinner ? Pls. Don't.
I also have same problem. My UPS is not working at all. When there is power cut, everything is turned off. How much does new battery cost ? My UPS is Favourite P-Tronics that I bought way back in 2001.
---------- Post added at 09:23 PM ---------- Previous post was at 09:20 PM ----------
Its backup time must be limited to some period. Try posting name, serial number and also if possible a photo of it so that you might receive more specific support. I am not expert though, just my suggestion to get you better support.
An Old Lady Died In Her Childhood.
vwad is offline   Reply With Quote
Strange problem (cpu not starting) plz help me anyone yarasu Hardware Q&A 6 12-07-2010 10:22 AM
UPS (Uninterruptible_power_supply) and UPS battery Buying Advice? Help Digitians!!! RajivKumar123456 Hardware Q&A 6 02-07-2010 11:41 PM
Network Card Problem wizrulz Hardware Q&A 2 02-07-2010 07:35 AM
Monitor Problem drsethi Hardware Q&A 0 23-04-2010 09:53 PM
UPS or PSU causing problem? ring_wraith Hardware Q&A 13 01-01-2008 06:03 PM
- by kool
- by ax3
