Old 25-07-2010, 07:13 PM   #1 (permalink)
Question new system, please help...
Please help me,I want a good system which ought to have about 8GB RAM.So,please if you can tell me the most optimized configuration...
YATANA is offline   Reply With Quote
Old 25-07-2010, 07:48 PM   #2 (permalink)
Jaskanwar Singh's Avatar
Default Re: new system, please help...
fill this so that we can suggest you a good config for your needs!!
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
Old 26-07-2010, 12:04 AM   #3 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
1+ tell ur budget nd use
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Auto system boot for scheduled download!!!!!!!!!!! phreak0ut Tutorials 13 27-08-2007 06:12 PM
Sony PlayStation 3 (60GB) kinshuk99 Gamerz 6 16-06-2007 12:02 PM
Very Strange Problem!!! shivaranjan.b QnA (read only) 1 15-06-2005 09:00 PM
- by kool
- by ax3
