I am having a peculiar problem in my PC, My OS Windows XP and UBUNTU( in separate hard disks). Windows xp not booting in normal mode. Appears blue screen (not able to read the content) restarting. However it working in safe mode superb. In ubuntu the screen is freezing in login screen. I cannot able to identify problem, mem test shows no problem. However check disk in os drive (D drivein sata) is showing some cross linking even after running chkdisk. CPU test also normal. I have done all types of defect investigation, not able to locate the problem. Please help me.
My configuration is motherboard M2MX SE . AMD 64 x2 dual core processor 4000 , 2 GB ram Kingston , Sony dvd, sata 250 GB(windows XP) and Maxtor 40GB( ubuntu) hard disk
Event log shows ‘the computer has rebooted from a bug check. The bug check was 0x1000000a(0xde03c6, 0x00000006,0x00000000, 0x8052b8e0. a dumb was saved....
V core voltage is switching between - 1.376V, 1.360V, 1.390V (not constant)
Peter162in@yahoo.com
