Old 24-07-2010, 04:02 PM   #1 (permalink)
g_goyal2000's Avatar
Default HP Cartridge problem
I have an HP Deskjet F4288 All-in-One printer which is out of warranty.
It uses HP 818 black & HP 818 tri-color cartridge.
I have genuine, non-tampered cartridges installed in the printer.
The problem is, this morning the printer & cartridges were working fine.
But in the afternoon, when I turned on the printer, the tri-color ink light was flashing.
But when I swapped the color cartridge with another color cartridge, the printer worked fine.
So what's the problem with the cartridge?
What about it's warranty claim?
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline   Reply With Quote
Old 24-07-2010, 05:05 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: HP Cartridge problem
the cartridge is out of ink?
Cybertonic is offline   Reply With Quote
Old 24-07-2010, 06:30 PM   #3 (permalink)
Revolution's Avatar
Or,may be it dried...
Revolution is offline   Reply With Quote
Old 27-07-2010, 09:48 AM   #4 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
If you use HP Solution Center (software shipped with all HP printers etc.), it tells you ink levels. Have you tried that?
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Dell Studio 15 Display Inverter and DVD Writer Problem windchimes Hardware Q&A 2 24-05-2010 12:48 AM
Ubuntu 10.04 "Low Graphics Mode" problem after update krishnandu.sarkar Open Source 6 23-05-2010 05:35 AM
problem with 16GB Cruzer micro rohit330 Hardware Q&A 3 16-05-2010 08:59 PM
Problem in Copy/cut paste bhavik Software Q&A 2 15-05-2010 10:52 AM
Display problem - corruption, lines, video blinking g_goyal2000 Hardware Q&A 5 05-04-2010 05:40 AM
- by kool
- by ax3
