Old 22-07-2010, 03:59 PM   #1 (permalink)
WM guru
Default Gaming rig around 35-40k
1. What is the purpose of the computer?
A: Gaming and HTPC.
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yes
3. What is your MAX budget?
A:35-40k
4. Planning to overclock?
A:no
A:i have one copy of windows 7 64 bit ultimate.
A: 500gb
7. What resolution will the screen run at & whats the size of the screen you want?
A: 24" or 22" 1080p
A:2
A:no will be done by assembler
A: one week
A: yes want motherboard with USB 3 if it fits in budget.
A: speakers and OS.
A: i leave in interier of Karnataka but planning to buy it from Banglore.
drck is offline   Reply With Quote
Old 22-07-2010, 04:10 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: Gaming rig around 35-40k
Proccy : Athlon II X4 635 @ 5k
Motherboard : Biostar-785 @ 3.6k / Gigabyte GA-785GMT-USB3 @ 5.7k
RAM : 4GB(2*2) G. Skill F3-10600CL9S-2GBNT DDRIII @ 5.2k
HDD : 1 TB Seagate 7200.12 @ 3.3k
GPU : MSI HD5770 Hawk @ 9.7k
ODD : L.G. GH22NS50 OEM SATA DVD-Writer 950
Speakers : Altec Lansing 2.1 VS2621 @ 1.7k
PSU : Corsair VX450W @ 3.7k
KB,Mouse @ 1k
UPS : ur choice @ 2k
Total - 37k (If you choose Biostar) / 39k (If u choose Gigabyte mobo)
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 22-07-2010, 04:30 PM   #3 (permalink)
WM guru
thanks for quick reply....
i need to buy new monitor also in the budget. plus i have speakers so 1.7k less... ll come upto 45k if choose 22" benq 2230hd..
any other way out to bring it to aroung 37k altogether
Old 22-07-2010, 04:48 PM   #4 (permalink)
Excessive happiness
So 37-1.7k = 35.3k +Benq 21.5" G2220HD - Rs.8000
Total = 43.3k
Or else loose the GPU, say HD5770 to some GTS 250 @ 5.8k (Link)
So now you lose 9.7 - 5.8 = 3.9k.
39.1k total. Simple
PS Request
Old 22-07-2010, 11:23 PM   #5 (permalink)
WM guru
FINAL CONFUGERATION BUYING TOMORROW FROM BANGLORE....
PLEASE COMMANT
Processor AMD Phenom II X2 555BE(3.2Ghz, 2 cores, 6MB L3 Cache) 4900
Motherboard Gigabyte GA-785GMT-USB3 5700
RAM 4GB(2*2) G. Skill F3-10600CL9S-2GBNT DDRIII 5200
HDD 500 GB WD Blue 2000
GPU Sapphire HD5770 1GB GDDR5 9600
Cabinet CM Elite 310 1500
PSU/SMPS Gigabyte Superb 460 2200
Key Board Logitech SET - Optical Blk Mouse+ MMKB 700
MONITOR BENQ 2220HD 7700
ODD L.G. GH22NS50 OEM SATA DVD-Writer 950
AROUND 40 K....
Old 23-07-2010, 11:55 AM   #6 (permalink)
WM guru
hi guys.. give ur recomondation on above rig as i m going to buy it today.
Old 23-07-2010, 12:04 PM   #7 (permalink)
Excessive happiness
Change the proccy to Athlon X4 635 to get a Quad Core, rest is fine
PS Request
Old 23-07-2010, 01:48 PM   #8 (permalink)
Jaskanwar Singh's Avatar
change the psu to fsp saga II 500W @ 2.6k as well as the proccy to 635 as rajkumar mentioned
Old 23-07-2010, 03:56 PM   #9 (permalink)
Sorry for hijacking this thread but can someone suggest me a good config under 50k
Processor core i5
Motherboard ?
Graphics Card HD5850
Cabinet NZXT Gamma
Monitor BenQ 22' G2220 Full HD 7.5k or G2420 11.5k ?
Corsair VX450 (will it be sufficient ?)
RAM 4GB
Faun is offline   Reply With Quote
Old 23-07-2010, 04:18 PM   #10 (permalink)
Excessive happiness
Atleast you dont create separate thread for this (But next time try to post in Basic Guid to purchase thread)
You already chose everything.
Only thing is get i5 750 and Gigabyte mobo Gigabyte GA-P55-US3L @ 6.3k.
And for PSU go for VX550W @ 4.5k
Will be a good option for upgrading.
Get Seagate 1TB HDD around 3.3k
Now you're good to go.
PS Request
Old 23-07-2010, 06:53 PM   #11 (permalink)
Processor core i5
Motherboard ?
Cabinet NZXT Gamma
RAM 4GB
can you mention your usage please.....
Old 23-07-2010, 08:33 PM   #12 (permalink)
laborare est orare
Cilus's Avatar
As you mentioned Gfx card as HD 5850, I'm considering you want a gaming rig. Now at your budget, Core i5 is a very bad choice. They are over priced and at this price point you will get good AMD processors.
Here goes my suggestion:
AMD Phenom II X6 1055T @ 9.6k
Biostar TA890GXE @ 6.6k
2X2 GB Kingston DDR3 1333 MHz ram @ 5.2k
1 TB Seagate HDD with 32 MB Cache @ 3.5k
NXT GAMA @ 2k
BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
Gigabyte 550W @ 3.7k
Keyboard & Mouse & SATA DVD Writer @ 2k
Sapphire HD5850 1GB GDDR5 @ 15.8k
Total is coming around 55k. You can reduce the price by going for Phenom II 955 @ 7.7k, 500 GB HDD @ 2k
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Update on Gaming Rig @ 65K lionheart133 Hardware Q&A 5 12-07-2010 07:42 PM
40k Gaming PC funkysourav Hardware Q&A 66 30-06-2010 11:21 PM
help me get a decent gaming rig under 30k phil2097 Hardware Q&A 4 05-06-2010 08:41 PM
Help building a gaming rig vicky2008 Hardware Q&A 10 15-04-2010 12:23 AM
Need a gaming RIG in 55k cool.vicky Hardware Q&A 5 12-02-2010 02:00 PM
- by kool
- by ax3
