Old 22-07-2010, 10:07 AM   #1 (permalink)
Default Display problem in new PC
I alreday asked this question in another thread 25days ago, but i lost the forum.
I bought a new PC with config as below
Amd phenom x6 1055t
asua M4A88TM/USB3
4GB adata ddr3 1333mhz ram
XFX HD5770 GPU
Corsair vx550
But when i run games, sometimes a striped screen or black screen comes and PC hangs, with music running.....Sometimes when i press a lot of keys, it goes to desktop and a message comes saying display driver has stopped working, I tried lates drivers, that ruined my games performance, and the problem was still there. Plz suggest me what to do.
I am using win 7 32bit original...
shall i switch to 64bit?
ani1751 is offline   Reply With Quote
Old 22-07-2010, 11:35 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Display problem in new PC
Which driver you on..?
asingh is offline   Reply With Quote
Old 22-07-2010, 11:51 AM   #3 (permalink)
you should buy ps3 ..
Battery Travel Charger | Cell Phone Cases
davidtwhittle is offline   Reply With Quote
Old 22-07-2010, 11:56 AM   #4 (permalink)
its not the solution. and what do you think he should do with his new computer??? throw into garbage can??
http://thenamemanish.blogspot.com/
mind021 is offline   Reply With Quote
Old 22-07-2010, 12:17 PM   #5 (permalink)
I mean if you really like play game then buy ps3 its awesome!!! if you play game in your PC then you should buy high resolution graphics card..
Old 22-07-2010, 09:06 PM   #6 (permalink)
I dont play games on it, I was just checking performance....and i got the bug...
At present i am using catalist drivers, provided with the card, and i also tried the latest drivers available on filehippo, but problem was not solved, and performance was down....
Old 23-07-2010, 12:10 AM   #7 (permalink)
Super Moderator
asingh's Avatar
Try 10.6 from the ATI site. The drivers you have would be legacy.
Old 23-07-2010, 01:35 AM   #8 (permalink)
Techie By Heart
mavihs's Avatar
Also switch to 64bit OS!
btw which Win7 Edition is it? & how much did you get it for?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 23-07-2010, 09:49 AM   #9 (permalink)
I changes to latest drivers(from ati site), let me check if problem still exist, and my original windows key is for 32bit, it will not work on 64bit, and i didnt purchased it, it was a gift. I am using win 7 ultimate.
Old 23-07-2010, 11:17 AM   #10 (permalink)
Techie By Heart
mavihs's Avatar
i think it will work! is it retail version?
Old 23-07-2010, 11:47 AM   #11 (permalink)
I have no idea, my brother give it me on phone, he asked me whether i wanted 32bit or 64bit, so i think i will not work, but if the problem still exist and there is no other way to troubleshoot it, than i will try 64bit, formatting PC takes a lot of hard work .....
Old 23-07-2010, 12:15 PM   #12 (permalink)
Super Moderator
asingh's Avatar
If you buy Win7, I think you get both 32 and 64 bit on same bundle. The key should work.
Old 23-07-2010, 12:43 PM   #13 (permalink)
the dotmaster
borax12's Avatar
...bro probably doing these in order could help
1.heres the link to the 10.6 catalyst-Drivers & Support | GAME.AMD.COM
(it would be better to first download revo uninstaller...google it and the first link will help you......uninstall the previous driver and control center installation...)
2.power down the system.....and then check the gpu connection......onto the pc x16 slot.....push it down firmly....there should be a click sound after it fits down perfectly...actually the the gpu would be screwed down to the pc expansion back plate slot on your case so....it would be a good idea to unscrew and and install the card firmly again....
3...check ur display connetcor......ensure that the display connector ..both on the monitor and the card ...and connected properly....
4....then....check the display settings menu for native setting in the control center....go to system display properties...from the desktop....set the screen res to your native screen res and frequency(i guess it would be 60Hz....only)...
before all this....go to the bios and revert all the board setting to default...settings...ths option is there on the first menu page....save and exit.....
i hope this helps...and yes switching to win 7 64 bit won't help you on this problem...but will definitely give you more room on the hardware front.....64 bit os have support for more hardware resources...esp the RAM and all....but in general it wont help u out on this problem...
i hope that helps...otherwise.....
well can do more about this, i guess!!(hey i forgot, what next?)
borax12 is offline   Reply With Quote
Old 26-07-2010, 09:30 PM   #14 (permalink)
Done all that, nothing solved, The problem remained silent for few days after new drivers installed, No when i started GTA 4, It was not running smoothly, even in lowest graphics... than suddenly the devil screen showed up... and here i am again!!
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 16393
Old 26-07-2010, 09:39 PM   #15 (permalink)
Wise Old Ghoul
Piyush's Avatar
any other game with same problem now?
or it is the same with all the titles?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 26-07-2010, 09:53 PM   #16 (permalink)
GTA 4, and all others... i will also try arkham asylum in few days....
Old 26-07-2010, 10:02 PM   #17 (permalink)
Wise Old Ghoul
Piyush's Avatar
have u tried out the latest patch
however i think its the problem with ur drivers
--Get Backers
Old 26-07-2010, 10:08 PM   #18 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
This is just a driver issue.
Make sure that
You have installed the latest drivers from ATI
Internal Graphics in board is disabled.
All chipset drivers are installed.
Windows driver updates are up to date.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 26-07-2010, 10:09 PM   #19 (permalink)
Well m8 ATI have some issue with windows 7....the drivers and all are not proper or something like that..I can't help you much with the full but for that sprips thing try this:
open ati control panel(by right clicking on your disktop and selecting the first option)
in there select desktop and display.
then at the bottom of the sceen you can see your monitor just above it a small black arrow press it and select configure
then you can see the property select full sceen well if the option is like not selecteable decrease your resolution a bit and then change it.then you can change your resolution back and your game will come fullsceen..
well I had this issue some days back on my bro's lap and found the solution from the new somewhere not sure where...but all thanks to the orignal guy...and hope it help you a bit...
NJempire is offline   Reply With Quote
Old 28-07-2010, 10:40 AM   #20 (permalink)
I have four sockets for RAM, I just put my RAM to the higher socket for 1600mhz, And i guess the problem is solved..... Just praying it will not blow my ram..... and suggestions about sticking to 1600 slot, shall i switch to 1333 slot again...??
Old 28-07-2010, 03:13 PM   #21 (permalink)
What The.... !!!
funkysourav's Avatar
well i am shocked to hear that the driver issues for HD5770 hasn't been fixed yet by ati!!
i hope your problem gets solved ani
---------- Post added at 03:13 PM ---------- Previous post was at 03:08 PM ----------
funkysourav is offline   Reply With Quote
Old 29-07-2010, 09:06 AM   #22 (permalink)
THE PROBLEM is Still there, just its frequency is reduced!!
Old 29-07-2010, 09:24 AM   #23 (permalink)
pulsar_swift's Avatar
problem with mobo ?
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 29-07-2010, 06:57 PM   #24 (permalink)
not sure, is it possible??
Help Please problem with LCD jatt Hardware Q&A 4 04-06-2010 06:25 PM
Help Please problem with LCD jatt Hardware Q&A 0 03-06-2010 07:12 AM
system boots but no display vickybat Hardware Q&A 2 19-03-2010 11:48 AM
Wierd LCD problem Psychosocial Hardware Q&A 2 10-03-2010 02:20 AM
- by kool
- by ax3
