Old 20-07-2010, 07:33 PM   #1 (permalink)
Default Need help regarding bluetooth speed...
I am currently using a old bluetooth
dongle which is class 1. I use it to
connect my nokia 5800 as a
bluetooth modem. The maximum
speed i get is around 60KB/s. If i
connect my phone throughusb cable
i get around 200KB/s. My friend told
me to get class 2 dongle since it will
offer high speeds..so is it worth
buying and will i see faster speeds?
Thanks...
sushantvirdi is offline   Reply With Quote
Old 21-07-2010, 07:19 AM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Need help regarding bluetooth speed...
I have never seen that kind of speed on my PC, it always ranges between 30-35KBps, the speed you are getting is very good.
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 21-07-2010, 08:55 AM   #3 (permalink)
dats bcoz i am using bsnl 3g
Old 21-07-2010, 09:38 AM   #4 (permalink)
CA50's Avatar
get a 2.0 one, that will increase the speed and will also provide better connectivity.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 21-07-2010, 11:38 AM   #5 (permalink)
thnks for ur reply bro..can u tell the maximum speed i can get with it?
Old 21-07-2010, 11:57 AM   #6 (permalink)
Cool Buddy's Avatar
what's 3G got to do with bluetooth? I thought you were talking about bluetooth file transfer speeds, seems I was mistaken. But my bluetooth file transfer speeds never cross 40KBps, so how can one get 60KBps Internet through it?
Nokia 5230 :(
Old 22-07-2010, 11:55 AM   #7 (permalink)
icebags's Avatar
its probably that fone has BT v2+EDR - thats why he is getting better speeds.
however , class of a BT dongle actually defines its range/transmit power. it doesnt mean better speed.
icebags is offline   Reply With Quote
Old 22-07-2010, 12:51 PM   #8 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
BT 2 will certainly give you better speed...but I am surprised to see your USB connectivity speed also...bcuz when I connect my mobile with cable I get >400Kbps (same 3G connection)...
BT is also a bad idea because it drains battery sooner...more frequent charging means battery will die soon...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 22-07-2010, 01:10 PM   #9 (permalink)
geek........
Gauravs90's Avatar
Ya get BT 2 class bluetooth dongle from IVT if you can find
Gauravs90 is offline   Reply With Quote
Bluetooth 4.0 Finalized, Brings 3 Modes topgear Technology News 3 30-04-2010 04:41 PM
Increase Utorrent Download Speed using Tweaking!! Krazzy Warrior Tutorials 28 10-12-2009 08:05 PM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
- by kool
- by ax3
