Old 19-07-2010, 06:41 PM   #1 (permalink)
Nemes!s's Avatar
Lightbulb G.skill DDRIII 1333 on Biostart TA785G3 mobo
Hi Guys..I'm back again
I wanted to know does Biostar TA785G3 supports G.Skill DDR III 2 Gb F3-10600CL9S-2GBNT 1333 mhz RAM ?
Coz i just checked the mobo spec and it is not showing G.Skill support
BIOSTAR :: TA785G3 :: Memory Support
Please shade some light
Thanks
Nemes!s is offline   Reply With Quote
Old 19-07-2010, 07:39 PM   #2 (permalink)
Default Re: G.skill DDRIII 1333 on Biostart TA785G3 mobo
it'll support. there shouldn't be any problem. not on support list doesn't mean its not supported but its not validated for support or say tested by Biostar.
Old 20-07-2010, 02:00 PM   #3 (permalink)
Nemes!s's Avatar
Thnx Sam..for clarifying the doubt
Old 20-07-2010, 06:16 PM   #4 (permalink)
android lover
kamal_saran's Avatar
Hey nemesis bro is that biostar mobo working well . Actually i also want to get that one but confused because it is not too popular in my city
kamal_saran is online now   Reply With Quote
Old 20-07-2010, 08:25 PM   #5 (permalink)
Nemes!s's Avatar
Well I have not yet bought it .... but some good experts here suggested me the same... But I'm looking at some reviews on this board...looks like this board has some probs...like incompatible memory and all... I think I should look for some other board...
Thnx for raising the alarm
Old 20-07-2010, 08:27 PM   #6 (permalink)
Jaskanwar Singh's Avatar
that mobo is nice one..
Old 20-07-2010, 09:09 PM   #7 (permalink)
Nemes!s's Avatar
I just found that ASRock M3A785GXH/128M @ Rs 5.1K is pretty awesome as compared to that Biostar TA785G3 @ Rs 4.7K and the price diff is just few hundreds... Looks like we got he winner
check out the specs for ASRock M3A785GXH/128M
Below is a list of the board's features as listed in the product manual:
  • Support for Socket AM3 processors: AMD Phenom™ II X4 / X3 / X2 (except 920 / 940) and Athlon II X4 / X3 / X2 processors
  • ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
  • Supports CPU up to 140W
  • AMD 785G + SB710 Chipsets
  • Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
  • FSB 2600 MHz (5.2 GT/s)
  • Supports Hyper-Transport 3.0 (HT 3.0) Technology
  • Supports Dual Channel DDR3 1600(OC)/1333/1066/800 (4 x DIMM slots) non-ECC, un-buffered memory, Max. capacity up to 16GB
  • Integrated AMD Radeon HD 4200 graphics, DX10.1 class iGPU, Shader Model 4.1, Max. shared memory 512MB
  • Built-in 128MB DDR3 1333(OC)/1200MHz SidePort Memory
  • Supports ATI™ CrossFireX™, Hybrid CrossFireX™ and 3-Way CrossFireX™
  • 3 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode, orange @ x4 mode)
  • Three VGA Output options: D-Sub, DVI-D and HDMI
  • Supports HDCP function
  • Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
  • 6 x SATAII 3.0 GB/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and JBOD), NCQ, AHCI and "Hot Plug" functions
  • 1 x eSATAII Port
  • Supports 2 x IEEE1394 ports (one port on back panel, one header on board)
  • PCIE Gigabit LAN 10/100/1000 Mb/s
  • Supports ASRock Instant Boot, Instant Flash
  • Supports Smart BIOS, EZ OC, ASRock OC Tuner, Intelligent Energy Saver
  • EuP Ready
  • 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888Audio Codec).
  • Windows® Vista™ Premium 2008 Logo Ready
  • I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x HDMI port, 1 x Optical SPDIF Out Port, 1 x IEEE 1394 port, 1 x eSATAII Port,1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
Old 23-07-2010, 05:25 AM   #8 (permalink)
android lover
Biostar mobo ta785g3 HD having street price of 3.5k
Old 23-07-2010, 05:32 PM   #9 (permalink)
Nemes!s's Avatar
Hi kamal
I think you refering to ATI 785 Chipset TA785GE 128AM which cost 3.5K
TA785G3 cost 4.3K
Old 23-07-2010, 06:49 PM   #10 (permalink)
Originally Posted by Nemes!s View Post
Hi kamal
TA785G3 cost 4.3K
HD cost 4k. the AsRock is nothing like a super mobo. its just a 785G with Xfire or say a Biostar TA785G3 HD (in ATX form) having 3 way Xfire. it cost 5.*k. not some hundred more as its based on 785G. till you not require Xfire very badly, skip the AsRock & get Biostar or Giggy or MSI.
proccy + mobo @ 15000 + 1000 vndprkh.09 Hardware Q&A 13 20-04-2010 10:15 PM
Need advice on Mobo selection ojha_riddhish Hardware Q&A 8 01-04-2010 08:52 AM
mobo for amd a2 x4 630??? The Day Walker! Hardware Q&A 3 05-03-2010 04:05 PM
Is my Mobo limiting my Proccy's performance? ajai5777 Hardware Q&A 7 28-02-2010 02:17 AM
How to select a boot first device temporarily in MSI mobo? ajai5777 Hardware Q&A 0 21-02-2010 10:56 PM
- by kool
- by ax3
