Old 19-07-2010, 03:17 AM   #1 (permalink)
Default Computers For My Office (Help!!!)
________________________________
I have to buy some computers for my office. We will be using these computers for web development. Can you guys suggest any changes to help me in my decision. We will be working on scripts like SQL DB, ASP, Dot NET, PHP, JSP and some designing work.
I have decided on the following setup keeping a budget of Rs 20,000 per system. I found out these rates at Compare India website. Pls correct if anything is wrong. A expert view would be helpful.
AMD-Athlon II X2 240 : 2880
Gigabyte - GA-MA74GMT-S2 : 3000
iBall cabinet with 400w psu : 1700
Seagate - Momentus ST9500420AS (500GB) : 1950
Logitech - Classic K100 : 211
Microsoft - Basic Optical Mouse : 375
Acer - X193HQ : 5500
Transcend 1 GB 1300 MHz DDR3 Ram X 2 : 2000
TOTAL : 17616
VTX3D - HD4350 AX4350 512MD2 (Optional)* : 1970
Total (Optional)* : 19586
---------- Post added at 03:17 AM ---------- Previous post was at 03:14 AM ----------
Do suggest if the graphics card is required and can't the on board graphics handle the pressure?
CrackeDJ is offline   Reply With Quote
Old 19-07-2010, 02:56 PM   #2 (permalink)
Techie By Heart
mavihs's Avatar
Default Re: Computers For My Office (Help!!!)
if you can answer these question we can help you better!
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
Also whats your total budget for all your systems & the total no. of systems you want?
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 19-07-2010, 04:08 PM   #3 (permalink)
__________________________________
A:Web developement (Will be running s/w like SQL Server, Dot NET, Flash,Dreamweaver, Photoshop but for image resolutions for website requirements, Should be capable of runing php jsp scripts for web developement and office tools)
A:Yes
A:Rs 20,000 per system
A:No
A:Win 7 Ultimate
A:anything equal or greater than 320GB
A: minimum of 1280 X 1024, 17"
A:7
A:yes
A:yes
A: Yes but the current setup should serve my requirements for 3 yrs at least
A:No
A:Bhubaneswar and yes i'm willing 2 buy from other city if it saves me some money
A: I need best value for money and warranty, brand is not that important if it performs well and delivers what it promises.
A: 2 lac, I will be requiring 10 of those PC as of now that comes down to 20K per machine.
Hope now i'll get some answers and suggestions.
Old 19-07-2010, 04:53 PM   #4 (permalink)
The Assassin
Cybertonic's Avatar
AMD-Athlon II X2 240 : 2700
Gigabyte - GA-MA74GMT-S2 : 2700
Zebronics Bijli with inbuilt PSU : 1500
Western Digital Caviar Blue 500GB - 2000
Dell E1709W : 5500
Kingston/Gskill 2 GB 1333 MHz DDR3 Ram : 2500
TOTAL : 17486
Better not go with compareindia, its prices are usually outdated or not correct.
The monitor price listed by compareindia is pretty low, google shopping shows it at 6000-7000
If you really want a Graphics card go for Biostar 785 G3 HD for 4000.
Cybertonic is offline   Reply With Quote
Old 19-07-2010, 05:07 PM   #5 (permalink)
@ Cybertronic: thanks for the update and suggestion but forgive me if i am asking too much bangs per buck, but can i have a system with grafix card under 20k?
Old 19-07-2010, 05:34 PM   #6 (permalink)
Processor: Athlon II X3 425 2.7GHz @ 3.5k
Motherboard: Biostar TA785G3 HD @ 4k
Ram: A-Data 2Gb DDR3 @ 2.3k
Graphics Card: -
PSU: -
Cabinet: Zebronics Bijli with bundled PSU @ 1.5k
Hard Drive: Wester Digital 500Gb Green @ 1.9k
Monitor: Dell S2009W 20” @ 6.6k (from SMC International)
Keyboard-Mouse: Logitech Internet Desktop Pro @ 0.6k
Total: 20.4k. as it crossed your budget, get 18.5" monitor. or drop the motherboard for the more simple G3 version. but don't go for 17". they to small & resolution too low.
---------- Post added at 05:34 PM ---------- Previous post was at 05:29 PM ----------
a graphics card will be a bad choice when your systems won't be used in gaming. also the resolution not so high. IGP will handle it just perfectly.
Old 19-07-2010, 05:34 PM   #7 (permalink)
The Assassin
Cybertonic's Avatar
for the remaining money from my config you can only get either HD 4350 512 MB or after a bit of bargaining (or buying in bulk in your case) HD 4550 512 MB
Old 19-07-2010, 09:31 PM   #8 (permalink)
Jaskanwar Singh's Avatar
whats the use of buying the cards which will become useless soon!!!!
Which is best office (2007 or 2010)? prathameshra Software Q&A 25 03-07-2010 10:35 AM
LAN (4 computers) connection in BSNL type 2 modem H.Lalnunmawia Software Q&A 4 02-07-2010 06:34 PM
[Urgent] MS Office Licence. Charan Software Q&A 12 27-08-2007 08:19 PM
Pay Rent to use Office 2003 instead of purchase navjotjsingh Technology News 3 31-01-2007 10:37 PM
Couldn't install OfficeXP lahratla Software Q&A 6 05-08-2005 06:44 PM
- by kool
- by ax3
