Old 18-07-2010, 11:06 PM   #1 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Bend pins
Please help
got my new phenom x 6 cpu pins bend
please say it can be repaired ?
AMD Phenom x6 1055T @3.50ghz || MSI R6850 @925Mhz OC/PE || 2X2 GB RIPJAWS 1333CL8 || CM 460W REAL POWER ||Asus M5A97 EVO || Lancool PC-K62 || Sennheiser HD201+Fiio E5 || Logitech G400+Razer Golathius || Epson TX121 with CISS || Arch Linux ||
saurabh_1e is offline   Reply With Quote
Old 19-07-2010, 12:03 AM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: Bend pins
If you can unbend the bent without breaking it... it should work just fine.
P.S.: Try it on your own risk.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 19-07-2010, 12:07 AM   #3 (permalink)
Originally Posted by saurabh_1e View Post
Please help
how it got bend? were you playing with it? well as vamsi said, should work fine. don't try unbend it too fast.
Old 19-07-2010, 12:10 AM   #4 (permalink)
AJJU
azzu's Avatar
YouTube - Fixing a Bent / Broken Pins on a CPU (NCIX Tech Tips #36)
check that link
if u be more specific about bend angle and no's pins bended
its"ll b more help to answer ur question
hope this helps
I love and Live to Design
azzu is offline   Reply With Quote
Old 19-07-2010, 10:17 AM   #5 (permalink)
Super Moderator
asingh's Avatar
How did you bend them. To it slowly with a safety pin or something. Really gentle.
asingh is offline   Reply With Quote
Old 19-07-2010, 10:55 AM   #6 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Returning to forum after a long time .
Got 12 pin straightened
cpu came out with hsf now only the only thing is running cpu without thermal paste .and afraid to take the cpu out again and put some thermal paste
a little bit of stock paste is there
Old 19-07-2010, 04:45 PM   #7 (permalink)
12 :shocked: how that happened?
well you can run the proccy without thermal paste but be ready to counter very high temps. so best is slowly detach the proccy from HSF (if it have got stuck). apply TIM. put in back on place.
Old 19-07-2010, 10:50 PM   #8 (permalink)
CA50's Avatar
How the hell did you succeed in bending 12 pins??
Now trying bending 24 pins and apply the TIM.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 19-07-2010, 11:42 PM   #9 (permalink)
Super Moderator
asingh's Avatar
You would need TIM. The CPU does not need to be removed to apply TIM.
Old 20-07-2010, 01:45 AM   #10 (permalink)
Techie By Heart
mavihs's Avatar
it must have got stuck coz of the stock TIM, it won't get stuck again. get some good TIM & you won't face prob of it getting stuck again!!!!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 21-07-2010, 07:24 PM   #11 (permalink)
teh tech saviour!
saurabh_1e's Avatar
it got stuck because of stock tim
the procy came out with the hsf in lock mode
take out the procy from hsf by using acetone and spirit and a hair drier
straighten the pins using mechanical pencil that is a lead pencils
now i don't think little bit of stock tim left will be so adhesive that it will stuck again
recommend a cheap tim
it shud not be adhesive and shud not conduct electricity
Old 21-07-2010, 09:49 PM   #12 (permalink)
wow did not know this could happen...now need to be extra careful while OCing subzero. Same advice to u mavihs
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 21-07-2010, 11:25 PM   #13 (permalink)
^^ me have to be careful. looks like the supplied TIM with AMD HSF is of very very low quality
Old 21-07-2010, 11:36 PM   #14 (permalink)
Techie By Heart
mavihs's Avatar
you do sub-zero OCing?
this has happened with me before, now i don't use stock TIM ever!
also when you doing sub-zero, after you finish OCing, you have to leave the CPU alone for some hours to heat up before you take it out! (recently i had done a OC at an event & had left the CPU alone & some guys (i don't know who) tried to take the pot out. when i got back, the pot+the CPU where out & half of the pins were bent! :'( (it was AMD 1090T proccy))
---------- Post added at 11:36 PM ---------- Previous post was at 11:34 PM ----------
its not AMD alone, even Intel's is low quality too! & they put paste like which can go on for 3yrs & which the person using it can't take it out!
Old 22-07-2010, 12:05 AM   #15 (permalink)
dude the TIM on Intel is total ****....i had done DICE at frens place, but we did not w8 much. We got the temp up using a hair dryer. Dont know if it is the right way....
Old 22-07-2010, 12:19 AM   #16 (permalink)
you did NO2 OC? how much you reached?
to cut manufacturing cost (& fill their own pocket) they'll try save on anything
Old 22-07-2010, 12:28 AM   #17 (permalink)
Techie By Heart
mavihs's Avatar
we couldn't get LN2 so we had to do it with DICE(Dry Ice). got it upto 5.4GHz!
its also to keep the cost low of the proccy!
---------- Post added at 12:28 AM ---------- Previous post was at 12:25 AM ----------
you did NO2 OC?
Getting Light to Bend Backwards naveen_reloaded Random News 3 19-10-2007 11:03 PM
bend of motherboard agasti CPU / Motherboards 1 27-09-2005 10:33 PM
HDD pins broken zegulas QnA (read only) 4 18-08-2005 07:02 PM
Bios Unleashed rajat22 Tutorials 2 10-04-2005 10:41 PM
- by kool
- by ax3
