Old 18-07-2010, 03:31 PM   #1 (permalink)
Exclamation Where is the missing space??????????
Hi guys.
I have a very strange problem. I gave my niit instructor my Moserbaer 4gb pendrive to give me MS VS 2005 setup when he gave it back to me, it was infected by a virus tazelbama.dll and had Nokia73tools and SonyEriksonTools. I deleted all the stuff and now it shows the capacity as 1.85 gb!!!! I also had a kingston 4gb which had a utility for making two partitions-public(485mb) and private(the last one required password to log in) i absent mindely formated the pendrive while it was in public mode. Now it has only 485 mb of space. Please help me asap as the moserbaer one i had borrowed from someone!!!!! :@
pranav.seth is offline   Reply With Quote
Old 18-07-2010, 04:31 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: Where is the missing space??????????
First run a scan from a paid or online antivirus, and then format it again
---------- Post added at 04:31 PM ---------- Previous post was at 04:29 PM ----------
not sure abt the kingston one though
Cybertonic is offline   Reply With Quote
Old 18-07-2010, 07:30 PM   #3 (permalink)
guys plz help!!!!!!!!!!!
Old 18-07-2010, 07:51 PM   #4 (permalink)
pranav, i not sure but you can try deleting the partition from the pendrive though My Computer>Manage>Disk Management. than try delete the partition. if you successful, you should be able retrieve the used space back by formatting. but usually it won't work. Warranty covers these issues so no worry.
@Cybertonic, it'll hardly make a difference. the pendrive formatted. so paid or free or pirated. everyone will give Clean result.
Old 19-07-2010, 10:18 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Format the pen drives.
asingh is offline   Reply With Quote
Old 19-07-2010, 09:08 PM   #6 (permalink)
no success.....no option available for deleting partition....don't have the bill of the pendrives and don't know the shop as someone else got it for me....how to claim warranty?
Old 19-07-2010, 10:38 PM   #7 (permalink)
CA50's Avatar
use the formating utility that came with the flash drive. The one with which you created the partition.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 20-07-2010, 03:39 PM   #8 (permalink)
that was formatted when i earlier formatted the pendrive and there was no partitioning option in that
Free web space and and domain clmlbx Chit-Chat 10 30-08-2010 01:47 AM
missing harddisk space harshit099 Software Q&A 7 03-04-2010 07:56 PM
help needed!! space missing on ubuntu arkadeep Open Source 3 18-03-2010 06:08 PM
Low Space Mangal Pandey Software Q&A 4 08-02-2010 04:36 PM
hard disk space missing!! arcticflare QnA (read only) 9 07-06-2005 09:12 PM
- by kool
- by ax3
