Old 18-07-2010, 02:15 PM   #1 (permalink)
Exclamation Intel's Atom Vs Dual Core Vs Alternatives
Intel Atom Vs ???
A Performance Balance
Hi Folks,
I am willing to assemble a new desktop computer, probably for the intensive programming apps I use on my current AMD Athlon64 3800+.
I already got a spare monitor, a 1TB HDD (yes thats 1000GB, 7200RPM, Western Digital which was not compatable with my current system, so is hidden in my locker without any use, more info google "WD10EARS"),a 1GB DDR 2 RAM(possibly getting from a friend).
Now, my preffered OS will be Linux (Red Hat), or Solaris.
I will be performing only those tasks which I perform on this current systems, so instead of comparing Atom with Core 2 Duo, which most tech sites have done, lets compare it with my old AMD processor.
Please put your views further, which core I should prefer, and if any easy alternative is available in the market. What I am considering is wraping the whole computer below Rs 6000.
aquafin is offline   Reply With Quote
Old 18-07-2010, 04:30 PM   #2 (permalink)
The Assassin
Cybertonic's Avatar
Default Re: Intel's Atom Vs Dual Core Vs Alternatives
please fill this form so we can understand your problem better-
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:
3. What is your MAX budget?
A:
4. Planning to overclock?
A:
A:
A:
7. What resolution will the screen run at & whats the size of the screen you want?
A:
A:
A:
A:
A:
A:
A:
A:
Cybertonic is offline   Reply With Quote
Core i3 or core i5 based system GEEKCOMPUTER_GEEK Hardware Q&A 17 06-07-2010 04:57 PM
Diff. B/W Core i3 & Core 2 Quad & C2D rahulbalmuri Hardware Q&A 10 10-06-2010 09:05 PM
CORE i3 or CORE i5???? rahul_007 Hardware Q&A 59 26-03-2010 04:06 PM
AMD's Phenom X4 9850 gets pitted against Intel's Core 2 Quad Q9300 DigitalDude Technology News 28 14-10-2008 07:26 PM
- by kool
- by ax3
