Old 17-07-2010, 08:22 PM   #1 (permalink)
cool.aquarian's Avatar
Question Need advice on choosing RAM
Hi fellow Digitians,
My relative has an old Dell Inspiron 6000 running XP, which came from factory with 2x256mb PC2 3200 RAM and supports dual channel with max 1GB PC2 5300 in each slot.
Recently, one of the RAM stick seems to have conked off.
The major use of the Laptop is: Internet Access, chatting, movies, music and working on Office Documents. And he is against unnecessary spending right now.
So, I am confused whether to:
1. buy him single 1GB stick and use it with the working 256mb stick (with maybe later upgrade to 1GB) or,
2. buy him two 512mb sticks and tuck away the 256mb one.
How much would be performance difference in both RAM combinations 1.25 GB(single channel) vs 1GB(dual channel) considering his usage?
Also, if going for first option, should I place the higher RAM in DIMMA and lower in DIMMB, or otherwise around or it does not matter ?
Thank you
cool.aquarian is offline   Reply With Quote
Old 18-07-2010, 08:56 PM   #2 (permalink)
Default Re: Need advice on choosing RAM
Thank you
better sell out the extra 256Mb & settle for 2X1Gb stick. the performance will take quite a jump. or use 1GB + 256Mb. BTW whats is the processor & graphics?
Old 18-07-2010, 10:59 PM   #3 (permalink)
It has got Intel Pentium M 1.50GHz processor, Intel 915GM chipset with onboard graphics(64MB shared).
So, I feel 2x1GB is an overkill for XP system and such usage. The RAM combinations I am now considering are:
1. 256MB+1GB
2. 256MB+512MB
3. 2x512MB
which one to go for ? Please help. I need to finalize and buy the RAM tomorrow.
Old 19-07-2010, 12:15 AM   #4 (permalink)
1. 256MB+1GB
2. 256MB+512MB
3. 2x512MB
serious overkill. better go for 1Gb + 256Mb or say 512Mb X 2 but will be lot costly. opt for 1st option.
Old 20-07-2010, 02:24 PM   #5 (permalink)
Thanks.. I bought 1Gb.
Old 20-07-2010, 05:15 PM   #6 (permalink)
welcome BTW how much it cost?
Old 20-07-2010, 05:55 PM   #7 (permalink)
Kingston 1Gb cost me 1250 INR here in Delhi (original with warranty).
Need advice on choosing mobo for phenom 9550 Quad achtung Hardware Q&A 6 02-06-2010 06:48 PM
How to identify RAM type physically? Raghav Talwar Hardware Q&A 5 24-05-2010 03:39 AM
PC vs PS3 Zangetsu Gamerz 106 20-03-2010 09:25 AM
RAM upgrade.. need advice (single channel or dual channel ) g4m3rz Hardware Q&A 3 18-06-2007 08:15 AM
- by kool
- by ax3
