Old 16-07-2010, 04:26 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Addicted
Default how to use LCD monitor as TV
friends,
As lcd monitors are less expensive than lcd tvs , which lcd monitor supports dth connection as well as dvd plugins. Should be 22 inch , HD ready and with in budget 9-10 thousand.
the_souvik is offline   Reply With Quote
Old 17-07-2010, 01:23 AM   #2 (permalink)
Default Re: how to use LCD monitor as TV
LG have Monitor with TV. One such model is LG M197WA
Core i7 950 | Asus Sabertooth X58 | Corsair DDR-III 6 GB | Sapphire HD 5670 512MB GDDR5 | CoolerMaster 650W SMPS | Thermaltake VJ400G1N2Z | BenQ V2410 | AVerTV Volar Go M A833M | Sennheiser HD 202
chris is offline   Reply With Quote
Old 17-07-2010, 01:48 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
nope
LCD Monitors wont give you that features & quality as compared to LCD TV
! जय हिंद ! Proud to be INDIAN
satyamy is offline   Reply With Quote
Old 17-07-2010, 08:55 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
easy way to connect is get an LCD Monitor with HDMI/DVI and buy a HD DTH.
VarDOS is offline   Reply With Quote
Old 17-07-2010, 09:41 AM   #5 (permalink)
Well you can check out this very nice monitor tv from samsung
Multi Function Monitor - P2370MS - Desktop Monitior - Monitor | SAMSUNG
You can also check out this amazing product from AOC
Monitor TV 24
sanju_nlp81 is offline   Reply With Quote
Old 17-07-2010, 10:16 AM   #6 (permalink)
New Gen Guru
sujoyp's Avatar
Or if u have an old lcd monitor...just get a external tv tuner worth 1k and attach it with DTH box and lcd monitor...thats it
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is online now   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/129680-how-use-lcd-monitor-tv.html
LG M197WA Manuals, Support and Troubleshooting - Monitors This thread Refback 08-09-2010 03:53 AM
22" lcd monitor kartikkapo Hardware Q&A 30 24-06-2010 12:59 PM
Urgent Purchase of 26" LCD TV or LCD Monitor with TV Tuner sandeepkochhar Hardware Q&A 0 09-06-2010 01:49 PM
My Micro HT Setup Review “Onkyo 6200 HTiB, LG LH70 47 LCD, Panasonic BD60 BRp” sam9s Reviews 14 02-05-2010 05:00 PM
Plasma & LCD TV, what are they ... iMav TVs / Monitors 2 30-04-2007 11:49 PM
- by kool
- by ax3
