Old 14-07-2010, 03:20 PM   #1 (permalink)
himadri_sm's Avatar
Default need the best possible PC for 60,000/-
i need a configuration for rs60,000/-. it should include everything except the mouse & speakers. i.e i want monitor, keyboard, cabinet, PSU, HDD, RAM, M/B, Processor, GFX card & DVD-RW. my main purpose is 3D work(running max & maya, specially for rendering) with some gaming on the side. so i do not want a quadro card.a high end geforce or radeon is preferred.i am not biased towards intel or AMD so i would like to see both options.this PC need not be highly future proof but should have adequate upgrade possibility.i am not going to overclock anything.please provide both intel & AMD configs for comparison. thank you.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
himadri_sm is offline   Reply With Quote
Old 14-07-2010, 03:34 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: need the best possible PC for 60,000/-
Here goes your config:
Phenom II X6 1055T 2.8GHz @ 9.4k
MSI 880GMA-E45 @ 6k
RAM: 2 X 2 GB Kingston 1333 MHz DDR3 @ 5.1k
HDD: Seagate Barracuda 7200.12 1TB @ 3.4k
Monitor: BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k
Cabinet: Zebronics Reaper @ 1.7k or NXT Gama @ 2k
PSU: Cooler Master GX-650W @ 5.5k
Gfx card: Palit HD5850 1GB GDDR5 @ 15.5k
Keyboard & Mouse: At your choice @ 1.2k
Optical Drive: LG 22X SATA DVD Writer @ 1k
Total is around 56.6k. You can go for some good 120mm Cooler master fans at 1k.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 14-07-2010, 03:43 PM   #3 (permalink)
Excessive happiness
furious_gamer's Avatar
AMD Phenom II x6 1055T @ 10.2k
MSI 890FXA-GD70 (AMD 890FX) @ 10k
Corsair XMS3 4GB DDR3 1333MHz @ 6.2k
MSI HD5850 @ 15.5k / MSI HD5770 @ 9k
Corsair VX550W @ 4.8k
Cabinet - Ur Choice
WD Cavier Green 640GB @ 2.8k
AOC 20" @ 6.3k / BenQ G2220 @ 7.8k
Any DVD-RW @ 1.3k
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 14-07-2010, 04:07 PM   #4 (permalink)
himadri_sm's Avatar
can you please suggest nvidia gfx cards also?i've had problems with ATI when it came to 3d work(personal experience, nvidia geforce somehow seems to fare better).also since it supports 3d vision & my friend may eventually upgrade to a 3d monitor, so nvidia seems like a good choice.how is the monitor Dell ST 2210 compared to benq G2220?also what other options do i have between MSI 890FXA-GD70 & MSI 880GMA-E45?how is the MSI NF980-G65? the 890FXA has a lot of upgrade potential which isn't really necessary.maybe i can save a bit on the m/b?also 3gb RAM would be enough for now.
Old 14-07-2010, 04:31 PM   #5 (permalink)
laborare est orare
Cilus's Avatar
ya, I know, initially ATI cards were having lots of issues. There were bugs in their drivers and some heating problem too. My 1st two cards were from Nvidia, 6800 ULtra and 8800 GTX. But now the thing has been changed completely. And the price point of 16k, HD 5850 is unbeatable. It performs far better than Nvidia's offering GTX 465 @ 16.5k and comparable to GT 470 available @ 22k. It requires less power, generate less heat and much stable in loaded condition. Most of the competing Nvidia cards are having Heating issues in high load. Do some googling and find it out by yourself.
The only option available from Nvidia is MSI GTX 465 1024MB GDDR5 @ 16.5k, performs almost same (marginally better) as Radeon HD 5830 @ 14.5k.
Old 14-07-2010, 04:43 PM   #6 (permalink)
The Assassin
Cybertonic's Avatar
MSI 880GMA-E45 @ 6k
Change
the motherboard to MSI 890GXM-G65 at 7.2k
PSU to corsair TX650 at 6.5k
HDD to WD caviar green 1 TB at the same price (Western Digital drives have been found to be more reliable)
Mouse to Logitech MX518 (gaming mouse) at 1.5k
keyboard of your choice for 0.5k
and you're good to go
Cybertonic is offline   Reply With Quote
Old 14-07-2010, 05:07 PM   #7 (permalink)
himadri_sm's Avatar
i do not want to debate about it but i have personally faced problems with my hd4850 while working with large complex scenes in maya...viewport rendering isn't as smooth as nvidia(i know this as my friend has a gt 240)his viewport rendering is much smoother than mine.i know rendering engines such as mental ray rely more on RAM & CPU power than actual GPU(onlya few rendering engines such as octane GPU renderer actually rely on GPU).also most of the times when i've rendered a scene that used the SSS shader, maya would crash.i am not going for a quadro or a fireGL as these cards pretty much suck for gaming(although performance in 3d work is far better).so to keep a balance between 3d & games, nvidia seems a better choice.this is why i asked about nvidia? how are the gtx 285 or gtx 295 cards in comparison to the gtx 465, 470 or HD 5850?
---------- Post added at 05:07 PM ---------- Previous post was at 05:02 PM ----------
EDIT: didn't see your reply. don't you think the TX650 would be overkill?also i already mentioned that i do not need a mouse.please read my post & tell me what options i have in Nvidia?
Old 14-07-2010, 06:35 PM   #8 (permalink)
The Assassin
Cybertonic's Avatar
TX 650 is overkill but its better to be safe than sorry. A vx550 might be able to take the load of the system but i'm not sure. As for nvidia i'd recommend you wait for gtx 460.
As per reviews its cooler, smaller and better performing than gtx 465 and should be a bit cheaper than HD 5850. Although it has been found that hd 5850 is better than gtx 460 and this increases with the higher your resolution.
---------- Post added at 06:35 PM ---------- Previous post was at 06:16 PM ----------
didn't find anything about rendering on the net but found a good motherboard for 1k cheaper. only downside is you don't get USB 3 and SATA 3. MSI 790GX-G65
Old 14-07-2010, 06:40 PM   #9 (permalink)
MSI 880GMA-E45 @ 6k
got a few suggestions:
1. the motherboard is good & cheap. else get the 890GX mobo from MSI.
2. get WD 500Gb green + 500Gb Black. one to render to & one to render from. performance increase is worth the extra cost.
3. get Corsair VX550W.
4. @himadri, better wait a couple of weeks. get GTX460 1Gb based card. suite your work. or you may get the same HD5850 for 13.5k or 14k than.
Dell sells the XPS 7100 with HD5870 & X6 1055T powered by a Delta 460W PSU. remember that.
Old 14-07-2010, 10:18 PM   #10 (permalink)
Go for an i7 processor....multi-threading will be of good help....for 3D work
shravan.kale is offline   Reply With Quote
Old 14-07-2010, 10:44 PM   #11 (permalink)
himadri_sm's Avatar
thanx Sam.Shab....i think i'll go with the 890GX....500Gb HDD will be enough...& i think the corsair vx 550w will also be enough.i think my friend might wait for a better graphics option though.is there any intel based system that you can recommend?
Old 14-07-2010, 10:55 PM   #12 (permalink)
with Intel, you simply have to switch the processor from X6 to i5 (else total cost will overshoot budget) & mobo to either H55/H57/P55. but in rendering, X6 + Nvidia looks good (until AMD slash graphics card pricing by a descent amount). also the card runs cooler (a bonus)
Old 14-07-2010, 11:33 PM   #13 (permalink)
himadri_sm's Avatar
ok.....so i'll go with the AMD setup...what do you think about 3d Monitors...my friend wants to buy a digital 3d system with the Nvidia 3d Vision Kit & Samsung Sync Master 2233RZ monitor.so now he is willing to wait a while for the GFX card.so now the config is- AMD Phenom II X6 Processor [ Model 1055T ]----------- Rs:10327/-
MSI 890GXM-G65--------------------------------------- Rs:7035/-
Corair PSU-550VX----------------------------------- Rs:4568/-
Corsair 1333 Mhz DDR3 3GB RAM--------------------- Rs:4400/-
WD 500GB Black --- Rs:2678/-
NZXT Gamma------------------------------------------- Rs:2030/-
HP DVD-Writer Model 1260i - ----------- Rs:1300/-
Samsung Sync Master 2233RZ monitor--------------------Rs.23100/-
Nvidia 3d Vision Kit- Rs.8400/-
Keyboard- Rs.500/-
The total setup is now at Rs.63828/-.he is willing to extend his budget but only for the extra digital 3d hardware. is there any alternative 3d display available?
what do you suggest?
Old 15-07-2010, 12:12 AM   #14 (permalink)
Keyboard- Rs.500/-
GTX460 will support 3D but the pricing for now is really high for the monitors. also let the quality will improve ver time. maybe won't require the glasses.
get 4Gb ram. 2X2Gb. dual channel.
about 3D i don't have any good idea
Old 15-07-2010, 03:01 PM   #15 (permalink)
himadri_sm's Avatar
thanx for the help....i'll let you know when the config is finalised.
Old 15-07-2010, 07:02 PM   #16 (permalink)
had done a guide for such PCs some time back and recommended the same config as the guys here. Just a little confused on the graphics as none of these graphics cards will help you much with rendering. Anyone here tired softmoding ?
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 15-07-2010, 07:13 PM   #17 (permalink)
Techie By Heart
mavihs's Avatar
ATI 5000 series are way better (also compared to 4800 series) in rendering wise! lots of my friends are your it for rendering!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline   Reply With Quote
Old 18-08-2010, 05:02 PM   #18 (permalink)
himadri_sm's Avatar
so i've decided upon this config with a budget of Rs.70,000/-
1.Processors- AMD Phenom II X6 Processor [Model 1055T]
2.Graphics card- ZOTAC GeForce GTX 470 1.25GB
3.Motherboards- MSI 890GXM-G65
4.SMPS- Corair 550VX
5.RAM- Corsair VS 1333 Mhz DDR3 8GB
6.Hard Drives- WDC 500GB Black S-ATA 3.5" Hard Drive
7.Cabinet- NZXT Gamma
8.Optical drive- HP DVD-Writer Model 1260i
9.Monitor- Samsung P2350
10.Keyboard- Logitech Multimedia
i've decided on 8gb of RAM because RAM is the most important component for offline rendering. now i know that in the NZXT gamma we can add upto 6 fans...but it comes with only 1 fan at the rear...now what i want to know is if i add the other fans...how should i add them..where should i add the exhaust fans & where should i add the intakes? also does it make a difference if i use any fan or should i only go for brands like coolermaster or any other?
Old 18-08-2010, 05:35 PM   #19 (permalink)
Techie By Heart
mavihs's Avatar
some changes i've suggested!
2.Graphics card- GeForce GTX 460 1GB
7.Cabinet- NZXT Gamma (have a look at CM Elite 430)
get fans with good CFM, that should be your main concern!
Old 18-08-2010, 06:04 PM   #20 (permalink)
himadri_sm's Avatar
i'll think about the graphics card at the time of buying...i am not going with the elite 430 as it costs rs.500 more than the nzxt gamma & is actually a bit smaller than the Gamma...could you please tell me how i should place the fans- the gamma's cooling system is- front- 1x 120mm, side- 2x120mm, top- 2x120mm, rear- 1x120mm(this is included, though i do not know if it is intake or exhaust)....i am thinking of adding 1 each at the front, side & top, but i do not know which fans to place where.the included rear fan is 23db/42CFM.so should i look for fans similar to this or does the intake fans need to be of a higher CFM than the exhaust fans?
Old 18-08-2010, 10:38 PM   #21 (permalink)
Fan Position:
TOP: 2 X 120mm exhaust.
FRONT: 1X120mm intake.
SIDE: 2X120mm intake.
the fan at the back, use it at front. this should offer some good cooling. or can fillup all the holes with fans but thats not necessary. 4+1 fan will be more than enough.
Old 18-08-2010, 11:04 PM   #22 (permalink)
What The.... !!!
funkysourav's Avatar
@all
do you think it is a good idea to recommend wd black hdd over cheaper and better performing seagate ones?(source tomshardware storage charts)
if op wants speed,
nothing can beat samsung spinpoint f3 as of now
funkysourav is offline   Reply With Quote
Old 18-08-2010, 11:04 PM   #23 (permalink)
himadri_sm's Avatar
Originally Posted by Sam.Shab View Post
Fan Position:
why is it necessary to use the rear fan in the front?should i use an exhaust at the rear?..also will it be enough if i use this arrangement-
TOP: 1 X 120mm exhaust.
SIDE: 1X120mm intake.
what kind of fans should i buy? branded or any generic ones?how much will a fan cost?(a basic, unbranded/branded non-LED fan)
Old 18-08-2010, 11:07 PM   #24 (permalink)
What The.... !!!
why isn't dell ultrasharp u2311h@13k make to the list of recommendations here?
this monitor is the most vfm performance monitor for any animation student!
Old 18-08-2010, 11:28 PM   #25 (permalink)
Techie By Heart
mavihs's Avatar
go to CM site check the cabby....it can accommodate two 5970's!!! also go for some higher CFM fans!
Originally Posted by funkysourav View Post
@all
if op wants speed,
link plzz!
+1
Old 18-08-2010, 11:43 PM   #26 (permalink)
fatalcore's Avatar
I personally feel elite 430 is better....somewhat
Gamma is good.....but cm better ( if you plan wisely ) ....
I will suggest you to buy a corsair Hydro cooling system for your system & get the 430.
To me.....sound really matters the most....6 fan will ring your ears at silent night after one year.
Watching movie at 2 am at night and the CPU fans creating noise at pin of silence in the movie is not acceptable to me.
(All the comments are Personal choice)
Utilize your funds wisely......70K is a hell lot of money....
Q9550+GA-EP45-UD3L+4GB CORSAIR DDR2 800FSB+XFX GTS250 1GB+250GB SATA+CORSAIR VX450+CM V8+ASUS XONER D2+SATURN+LGDVDRW+CREATIVE 5.1 INSPIRE+500GBX6 FREE GO AGENT+RAZER MOUSE+DELL LATITUDE 6400.
fatalcore is offline   Reply With Quote
Old 19-08-2010, 12:26 AM   #27 (permalink)
nothing like that. you surely can use any fan at the front. actually you not need so much exhaust fans. 2 exhaust, 3 intake will be more than enough.
Spinpoint F4 beats the F3. but F4 comes in a 320Gb size currently. F3 Spinpoint falls between WDC Blue & Black, but consumes power as low as Green.
what about the motherboard, graphics card? hydro cool them too? also water cooling is not so easy. and even if water cooled, only the processor will be cooled. for proper cooling, extra fans will be necessary.
Old 19-08-2010, 03:30 AM   #28 (permalink)
himadri_sm's Avatar
i am planning to buy this samsung 23" monitor- LINK don't want to spend more than 10-11k...so i think this one fits the bill...
As i said..elite is costlier....since i'll be adding extra fans anyway...i am going with the gamma
is it really going to be that bad? i currently have a zebronics antibiotic with three fans(all stock) & it is 2 years old & so far i haven't had any sound problems.
so how is this arrangement-
Front -1 Intake
Side -2 Intake
Rear & Top -1 Exhaust
BTW, how much is the spinpoint F3 @500gb going to cost?if its the same or lower to WD Black..i might consider it.
Old 19-08-2010, 07:55 AM   #29 (permalink)
Spinpoint F3 (stay away from F3 EcoGreen) costs ~1.9k for 500Gb.
Old 19-08-2010, 03:21 PM   #30 (permalink)
himadri_sm's Avatar
so its actually quite less than WD Black.i've never used any HDD other than seagate & WD....is Samsung reliable?
- by kool
- by ax3
