Old 13-07-2010, 11:10 PM   #1 (permalink)
dare_devil's Avatar
Default New rig under 20k in aug10
1. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
A:web surfing, movies in hd and games, at least capable of playing latest games on playable frames, do not high end performance in games
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
A:yes
3. What is your MAX budget?
A:20k for cabinet, processor, motherboard, ram, psu and gpu only. ready to increase if getting much higher performance just for few more bucks
4. Planning to overclock?
A: may be
A:windows 7 64 bit and open source linux
A:no hard disk required
7. What resolution will the screen run at & whats the size of the screen you want?
A: full hd
A:7
A:assembler
A:second half of august
A:yes
A:hard disk, optical drives etc
A:gurgaon and o to other cities other than delhi
A: nothing
Dell Studio 15, 2.1 Gh, 4 Gb Ram, 500 Gb hd, 512 mb ati 4570, creative sound blaster windows vista sp2
dare_devil is offline   Reply With Quote
Old 13-07-2010, 11:30 PM   #2 (permalink)
Default Re: New rig under 20k in aug10
Processor: AMD Athlon II X4 635 2.9Ghz @ 5k or get the X4 630 @ 4.8k
Motherboard: Gigabyte GA-MA-785GMT-US2H @ 4.5k or Biostar TA785G3 HD @ 4k
Ram: Corsair 2Gb DDR3-1333Mhz Value @ 2.5k
Graphics Card: Sapphire HD5670 512Mb @ 5.3k
PSU: FSP Saga II 400W @ 2k or Gigbayte 460W. whichever you find cheap.
Cabinet: CM Elite 310 @ 1.5k
Total: 20.1k. but i'll suggest get the HD5770 if you want Full HD gaming. also try include 4Gb ram.
Old 14-07-2010, 11:21 AM   #3 (permalink)
Jaskanwar Singh's Avatar
perfect one for his budget sam..
Jaskanwar Singh is offline   Reply With Quote
Old 14-07-2010, 10:23 PM   #4 (permalink)
dare_devil's Avatar
How much more buks i have to spend to get phanom based rig and will that be worth? Is this rig future proof?
Old 14-07-2010, 10:36 PM   #5 (permalink)
yes. somehow fit into his budget but it isn't suitable for Full HD gaming.
Phenom II won't increase performance. to get more performance, you need more ram & a little faster graphics card. like HD5770 based one. from MSI/Biostar/Sapphire. also 4Gb ram is a must for HD gaming.
---------- Post added at 10:36 PM ---------- Previous post was at 10:33 PM ----------
and about futureproof, i think if you do causal gaming or not indulge yourself in hardcore gaming, 3-4yrs. but will need change the graphics card over time if some newer tech like DX11.1 or DX12 comes out & dominates the gaming industry. other than that, the Athlon II X4s enough fast.
want advice on rig around 20k kamal_saran Hardware Q&A 47 01-08-2010 06:29 PM
Gaming PC For 20K muraliand PC Components / Configurations 36 30-07-2010 12:31 PM
suggestion in buying a new system for around 20k prasanthsd Hardware Q&A 5 10-07-2010 08:02 PM
Suggest AMD rig worth 20k urgent!!!! Vensanga Hardware Q&A 18 10-07-2010 01:10 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
- by kool
- by ax3
